02-04-2015, 15:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: djerba
Member: 1269161 Status: Offline Thanks Meter: 119 | i9195 stuck in logo !!! samsung i9195 stuck in logo after flash with 4.4.2 with original firmware( i use s/n to know original firmware) i recive phone with this problem and cant repair !! any help ! |
The Following User Says Thank You to .:B-A-G:. For This Useful Post: |
02-04-2015, 16:15 | #2 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | 1. wipe cache parttition 2. wipe data/factory reset 3. reboot. Check if any error when wipe. == if all okay. Try with 3files+pit. (Repair Files) |
02-04-2015, 17:15 | #4 (permalink) |
Junior Member Join Date: Feb 2015 Location: Bhilai Dhour Age: 28
Member: 2340028 Status: Offline Thanks Meter: 1 | Have u tried flashing it with odin if yes and it not working then check nand erase all option in odin then load firmware in pda then........lets go |
The Following User Says Thank You to Sourabh Manher For This Useful Post: |
02-10-2015, 03:21 | #7 (permalink) |
Member: 2340028 Status: Offline Thanks Meter: 1 | And if above procedure dont work then there is only one universal solution And that is-flash recovery like twrp or cwm and install a custom rom like paranoid or cyanogenmod your hang on logo problem will definitely solve after installing Keep in mind dont try to flash recovery with odin it may brick your device |
