02-02-2014, 07:56 | #2 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1806287 Status: Offline Thanks Meter: 4 | Same issue.... Selected model: I9195 Selected port: COM200 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9195 Android version: 4.2.2 Product code: GT-I9195ZKAO2U Phone version: I9195XXUBMJ7 PDA version: I9195XXUBMJ7 CSC version: I9195O2UBMJ1 IMEI: 3577370........... Phone S/N: RF........... Checking phone at COM200 OK Backuping NVM... OK Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.16.0 |
02-02-2014, 08:58 | #3 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: pakistan
Member: 583290 Status: Offline Thanks Meter: 107 | Quote:
02-02-2014, 11:35 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: morocco
Member: 587405 Status: Offline Sonork: 100.1681610 Thanks Meter: 151 | The procedure is as: 1_ Copy the " S4Mini_RootKit_v1.zip" to your device SD card. 2_ Turn off the phone. 3_ Press and hold home, volume down and power. Download screen should appear. 4_ Connect USB cable, and press volume up. 5_ Start Odin, uncheck "F. Reset Time", and then click AP button. 6_ Select "recovery-clockwork-6.0.3.7-serranoltexx.tar.md5" file that you previously extracted, and press Start button. The phone will reboot when finished. 7_ After the phone resets (it vibrates) IMMEDIATELY hold volume up and home buttons to boot into recovery mode. 8_ Select the option to install the ZIP file you have previously copied to your device and begin flashing it. 9_ After flashing using CWM, reboot into system and enjoy your rooted device. To get rid of the the warnings about applications doing not permitted actions, delete the following files from system/app KNOXAgent.apk KNOXStore.apk ContainerAgent.apk |
02-03-2014, 10:12 | #5 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: slovenia Age: 48
Member: 18028 Status: Offline Thanks Meter: 20 | Quote:
04-16-2014, 01:27 | #11 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | after install Vikinger, root check ok, but fail at bypass msl seem need downgrade modem or patch it. Selected model: I9195 Selected port: COM225 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9195 Android version: 4.2.2 Product code: GT-I9195ZWAFTM Phone version: I9195XXUBML2 PDA version: I9195XXUBML2 CSC version: I9195FTMBML1 IMEI: 351616063730145 Phone S/N: Unknown Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM225 Backuping NVM... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... error Done with Samsung Tool v.17.3 |
07-02-2014, 01:24 | #13 (permalink) |
No Life Poster Join Date: Feb 2004
Member: 56121 Status: Offline Thanks Meter: 107 | I can confirm what's Bourri GSM said... NEW 17.6 Samsung Tool is bugged ( as always for new versions )... Bypass MSL failed ALL THE TIMES with a i9195... IMEI repaired in 5 seconds with OLD 6.4 version that i kept... CUSTOMERS ARE NOT BETATESTERS... OUR TIME IS MONEY |
