12-15-2014, 13:36 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: Bangladesh
Member: 1024699 Status: Offline Sonork: 100.1622959 Thanks Meter: 600 | I9195 v4.2.2 Root & Unlock Full Procedure Step By Step STEP 1.Extract recovery-clockwork-6.0.3.7-serranoltexx.tar.zip file to your computer.(Download hereOdin_v3.09) & recovery-clockwork-6.0.3.7-serranoltexx.tar(1) Step 2.Copy the " S4Mini_RootKit_v1.zip" to your device SD card.File hereS4Mini_RootKit_v1 Step 4.Turn off the phone. Press and hold home, volume down and power Connect Micro USB cable, and press Start Odin, and then click AP button. Select "recovery-clockwork-6.0.3.7-serranoltexx.tar.md5" file that you extracted, and press Start button. The phone will reboot when finished. Step 3.After the phone restart on vibrate press hold volume up and home buttons to boot into recovery mode. Select the option to install the ZIP file (S4Mini_RootKit_v1.zip) you have previously copied to your SD card. and after installed just reboot, now your phone is succesfully rooted Step 4.Phone Must be powered on Step 5.Type *#0808# and choice DM Modem Adb Step 6.Reboot phone Step 7.Conect USB cable install drivers. Step 8.Select Samsung Mobile Usb Serial Port Step 9.Press Unlock Step 10.Enjoy Unlock Successfully done |
The Following User Says Thank You to SRASHED For This Useful Post: |
12-16-2014, 18:44 | #3 (permalink) |
Member: 1024699 Status: Offline Sonork: 100.1622959 Thanks Meter: 600 | install recovery-clockwork-6.0.5.0-serranoltexx.tar.zip with odin go to recovery without reboot to system install S4Mini_RootKit_v2.zip from recovery (from sd card)here..http://forum.xda-developers.com/atta...2&d=1390236639 reboot to system go to recovery again and install S4Mini_RootKit_v1.zip (from sd card) After post result...(full log info) |
12-23-2014, 19:10 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Age: 41
Member: 389660 Status: Offline Thanks Meter: 60 | Selected model: I9195 Selected port: COM93 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9195 Android version: 4.2.2 Product code: GT-I9195ZWAXEF Phone version: I9195XXUBNB3 PDA version: I9195XXUBNB3 CSC version: I9195XEFBND1 IMEI: 3548 Phone S/N: RF8F906FXYD Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM93 Backuping NVM... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... OK Unlocking... OK Checking phone at COM93 Restoring NVM... OK Reseting... OK Unlock done Done with Samsung Tool v.18.3 |
