06-16-2015, 06:53 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: earth
Member: 1598016 Status: Offline Thanks Meter: 61 | i9300 after unbrick I unbrick it with this sd card method Samsung s3 i9300 & Note2 N7100 & i95… | Samsung Galaxy S III I9300, I9305 | XDA Forums then flash with multi file firmware but now i need to flash efs.tar but problem is this that my phone not detect in dowwnload mode by 3 pc's. and can connect in sideload adb mode what is the problem |
06-16-2015, 14:36 | #4 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2056267 Status: Offline Sonork: 100.1659198 Thanks Meter: 26 | how is that ? computer can de3tect ur phone under ADB ! and there is nothing in download mode ?!! i think ur : changed usb cable changed usb port changed odin ! * to reset efs for i9300 using z3x u don't need download mode, ROOT and usb debuging needed! |
The Following User Says Thank You to Tulkarm For This Useful Post: |
06-16-2015, 17:48 | #5 (permalink) | |
No Life Poster Join Date: Nov 2013 Location: Third World ;)
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | Quote:
Is phone detected in device manager? Why do you need to flash efs? If phone boot up you can repair it another way. | |
06-17-2015, 07:19 | #6 (permalink) |
Member: 1598016 Status: Offline Thanks Meter: 61 | the mobile phone is stuck boot screen brother and show this error in recovery E:failed to mount /efs (Invalid argument) so that i need to flash efs.tar but my problem is solve now thanks for all i just change usb controller ic |
06-19-2015, 21:03 | #8 (permalink) |
No Life Poster Join Date: Apr 2008 Location: gsmsolution Age: 34
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | It's common problem when you unbrick dead i9300 via sd card ..I had same issu when I was unbrick my first set ..finally learned everything .. It's hard to explain here and posting links ..if you still not solved your problem contect me on mesangers (Skype better) |
06-19-2015, 21:06 | #9 (permalink) | |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | Quote:
I9300XXUGMJ9 Multi Android 4.3 | |
