09-13-2012, 07:42 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | *I9300 easy step to unlock with king z3x* 1 first of all need to Root your device Instructions: To begin, download the insecure kernel and extract the file to find a TAR file. Download the root package and extract the contents. Put the phone in download mode. Hold down the Volume Down key, Home key and Power key and when prompted, press Volume Down to enter download mode. Run ODIN and click PDA to select the TAR file you extracted from the insecure kernel zip package. Now connect the phone to the PC via USB and when you see the device connected in ODIN, hit the Start button in ODIN to begin the flashing. Once the phone reboots, make sure USB Debugging is enabled. Connect the phone to PC again if you disconnected it, and run install.bat found in the root package you extracted earlier on. The phone will reboot once again, and once done, you will have a rooted Galaxy S III. For updates and queries. after Root Setting/developer options /usb debugging / tick mark open z3x latest version exe. install latest version drivers .... Count supported models - 319 Android Version: 4.0.4 Model: GT-I9300 Product Code: GT-I9300RWDH3G Phone Version: I9300NELF1 PDA Version: I9300XXALF6 CSC Version: I9300H3GALF1 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.7 click Unlock and Enjoy how to select files for rooting phone see this pic for root need Odin3-v1.85.zip CF-Root-SGS3-v6.0.tar Last edited by haji rahim; 09-13-2012 at 07:46. Reason: spelling |
09-13-2012, 08:32 | #2 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | I have some remarks to your tutorial: - First of all, you are useing an outdated rooting file and can couse problems. CF-Root has an improved version 6.4 for S3. - Don't use 12.7 to unlock I9300 becouse there are many reports with damaged IMEI after unlocking. Use better 12.6 version - After you will upgrade this phone it will relock it self. If you don't whant this you need to use other tool for unlock |
09-13-2012, 09:36 | #4 (permalink) | ||
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Quote:
BR | ||
10-13-2012, 16:37 | #6 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Portugal Age: 41
Member: 241933 Status: Offline Thanks Meter: 77 | Yes it works 100% 1- Root your phone with CF-Root 6.4 , follow this guide all downloads requeried are there; CF-Root 6.4 -- It's the New Samsung Galaxy S3 Root Package, Includes CWM 5.5, SuperSU and CWM Manager App 2- After root your phone go to, settings, developer options and trick usb debugging. 3- Open samsung tool 12.6 select I9300 and do unlock direct 4- Unlock done PS: If your phone is not detected in download mode ,try use nokia usb cable CA-101 Model: GT-I9300 Done with Samsung Tool ver 12.6 Android Version: 4.0.4 Model: GT-I9300 Product Code: GT-I9300MBDORA Phone Version: I9300BVLE4 PDA Version: I9300BVALE4 CSC Version: I9300ORAALE4 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Unlocking... OK Rebooting Phone... OK Done with Samsung Tool ver 12.6 Last edited by badwily; 10-13-2012 at 16:44. |
10-13-2012, 16:53 | #7 (permalink) |
Member: 241933 Status: Offline Thanks Meter: 77 | * To check to see if your Galaxy S3 i9300 is fully unlocked, you can press *#7465625# A menu will be displayed that will resemble the following... 1. [ ] Network lock 2. [ ] Subset lock 3. [ ] SP lock If everything is OFF or DISABLED, your phone's network restrictions are all off, so it is fully unlocked. |
10-13-2012, 17:27 | #8 (permalink) | |
Member: 1722871 Status: Offline Thanks Meter: 116 | Quote:
Sent from my GT-I9300 using Tapatalk 2 | |
