09-17-2013, 09:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | I9300 flash problem Have you seen such an error?!What that means?Something's mess with the boot or what?!The set's been flashed once with Z3X just for regular flash,update,etc...and now...,after the flash process,this error...I can't flash it with Z3X,nor original flasher.If I try to hard reset it,the LCD comes out like a broken TV...Now what,mates?!Need assistance.Thanx.Here's the log. Code: Selected model: I9300 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x4B68900C Searching USB Flash Interface... detected COM31 Setup connection... OK Reading PIT from phone... Error Done with Samsung Tool v.15.5 |
09-19-2013, 08:32 | #9 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1522958 Status: Offline Thanks Meter: 24 | does it shows no pit partition if u flash via odin? if so byebye. First try rescue s3 firmware: [ODIN_FIRMWARE] SGSIII I9300 Prerooted Stock Odex/Deodex & Rescue FW - xda-developers if not try to flash all separate files with pit files. Theres 5 different pit files in total depends on GB and so: GT-I9300_mx_20120220.pit GT-I9300_mx_20120322.pit GT-I9300_mx_20120329.pit M0_20120220.pit mx.pit be very carefull with pit files you might destroy your phone |
09-19-2013, 12:29 | #10 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | So here's the log from the solution mention above by @kamertonas.Same thing.What's wrong with this pit file,I cant do anything with the set!?!... Code: <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> BOOTLOADER_I9300XXEMG4_1314436_REV00_user_low_ship.tar.md5 is valid. <OSM> CODE_I9300XXEMG4_1314436_REV00_user_low_ship.tar.md5 is valid. <OSM> MODEM_I9300XXEMG4_1314436_REV00_user_low_ship.tar.md5 is valid. <OSM> CSC_I9300OXAEMG4_KOR_FACTORY_user_low_ship.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/068> Odin v.3 engine (ID:68).. <ID:0/068> File analysis.. <ID:0/068> SetupConnection.. <ID:0/068> Initialzation.. <ID:0/068> Set PIT file.. <ID:0/068> DO NOT TURN OFF TARGET!! <ID:0/068> <ID:0/068> Re-Partition operation failed. <ID:0/068> Added!! <OSM> All threads completed. (succeed 0 / failed 1) |
09-20-2013, 02:13 | #11 (permalink) | |
Junior Member Join Date: Aug 2013
Member: 2007978 Status: Offline Thanks Meter: 1 | Quote:
07-21-2014, 01:28 | #12 (permalink) |
Junior Member Join Date: Mar 2014 Location: Kuwait
Member: 2142391 Status: Offline Sonork: 1656181 Thanks Meter: 13 | hello all recently i have seen one error in I9305 flashing i have flash that mobile with z3x box all this done perfect not a single error occur but after all done when mobile start build number is same and nothing data has been delete from that mobile after all flashing done but all data are there nothing deleted what is the problem no product name and imei is null Last edited by abbasi1; 07-21-2014 at 01:36. |
