10-22-2012, 14:19 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: In Mobile Lab
Member: 278476 Status: Offline Sonork: 100.1592375 Thanks Meter: 119 | i9300 imei Null please help z3x !!! |
10-22-2012, 14:22 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
check backup NVdate in backup and check posts, todya one customers repaired imei to original with some tricks. | |
10-22-2012, 14:35 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Quote:
10-22-2012, 14:39 | #4 (permalink) | |
Member: 278476 Status: Offline Sonork: 100.1592375 Thanks Meter: 119 | you are right Quote:
any ways,, such solution from nabel sweed is not working for me i mean unable to find modem after writing the efs data to and reboot the phone !!! need real solution please!! | |
10-22-2012, 14:41 | #5 (permalink) |
Freak Poster Join Date: May 2012
Member: 1759085 Status: Offline Thanks Meter: 4 | did you dump the i9300 before? u repair imei if yes u can write it back on the i9300 check the efs folder file will be there .bak extension u simply write to phone but then phone will go back to 0049 |
10-22-2012, 14:53 | #6 (permalink) | ||
Member: 278476 Status: Offline Sonork: 100.1592375 Thanks Meter: 119 | Quote:
What Should i do:: | ||
11-07-2012, 12:02 | #14 (permalink) |
Member: 278476 Status: Offline Sonork: 100.1592375 Thanks Meter: 119 | Alll is DONNNNE my unit become ok with working network with even non orignal imei with this patch to solve the problem of network http://www.arizandroid.com/patch/ariza_JBv02.zip copy it your sd card by using volume up + home + power buttons get into cwm menu and than - Install zip from sd card -choose zip from sd card and select ariza_JB02.zip - Please wait automatic reboot Hopes to help solve the problem of network |
08-24-2013, 15:55 | #15 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1669920 Status: Offline Sonork: altamash Thanks Meter: 3 | PLESE HELP SIR I9300 IMEI 0049 UNLOCK DONE IAM USED CABLE RJ45 C3303K SPT BOX CABLE C3300 HEAI IS LOG Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x4B138028 Searching USB Flash Interface... detected COM8 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_24-8-2013_17-11-31.pit Sending sboot.bin... Error Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x4B138028 Searching USB Flash Interface... not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x4B138028 Searching USB Flash Interface... detected COM8 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_24-8-2013_17-11-51.pit Sending sboot.bin... Error Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x4F3BD1CC Searching USB Flash Interface... detected COM8 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_24-8-2013_17-12-14.pit Sending tz.img... OK Sending sboot.bin... OK Sending system.img... OK Sending boot.img... OK Sending recovery.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Flashing done (time - 00:04:50) Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM7 Reading phone info... Software version: I9300XXEMD2/I9300XXEMC2/I9300OXXEMD1 IMEI: 004999010640000 Product code: GT-I9300RWDATO Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: GT-I9300RWDCYO Phone version: I9300XXEMC2 PDA version: I9300XXEMD2 CSC version: I9300OXXEMD1 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Repairing network settings... OK Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM9 No answer from phone Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: Not Active Phone version: I9300XXEMC2 PDA version: I9300XXEMD2 CSC version: I9300OXXEMD1 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Repairing network settings... OK Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM9 Operation aborted Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM24 USB Serial Port Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.15.3 Selected model: I9300 Selected port: COM24 USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: Not Active Phone version: I9300XXEMC2 PDA version: I9300XXEMD2 CSC version: I9300OXXEMD1 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Repairing network settings... OK Writing data to phone... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM24 No answer from phone Done with Samsung Tool v.15.3 Report Post |
