I9300 imei repair fails with Z3x ,why???? Android Version: 4.0.4 Model: GT-I9300 Product Code: Not Active Phone Version: I9300XXLEF PDA Version: I9300XXALEF CSC Version: I9300OXEALE4 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Writing NV Data To Phone... OK Rebooting Phone... OK Searching Samsung USB Modem... Not Found Help |
same here bro having the same problem here too. don't know what to do . z3x should do something about this it's really annoying. .... |
Me too, Z3X solution no IMEI and Unknow base band !!!!!!!! |
Not Possible Yet, Wait For Next Update... Or I read on some thread that someone somehow succeed to repair IMEI with 12.4, But I dont know how they done this...Use Search button you will find that kind of thread... & Its Recommended to use V. 12.6 to unlock I9300 because many LOST IMEI Case Done with 12.7. |
And how exactly are you going to do it with z3x when it is not supported? Have any of you even took the time to search the forum? There is a way, but the flash files needed are not available for z3x yet. You need to flash the phone with a special firmware and then repair your 049.... imei to make it go back as it was. right now I think 2 of the other tools can do it, |
Read Before Post.... I think you should Read my Post Twice, I haven't changed IMEI, I read in some threads that someone had successfully repaired IMEI with Z3X... And for your info. Z3X Supports Repair.. Quote:
Yes, they can write anything. But all depends on android version the phone has. I already suggested you to use the search button, if there is a successfully i9300 imei repair with z3x then it should be there at the results. Good luck Enviado desde mi A100 usando Tapatalk 2 |
z3x box not repair imei s5830i s5300 i9300 s5753e please check product supporter to bugs fixed |
z3x now theesee days have to much problem with softwear bugs ... realy need to fix themmm.................. we hope the gone find some solution for that.............. |
any buddy can upload samsung tool v12.6 |
Z3x i9300 imei Z3X is great tool has served us all well in past,unfortunately other boxes are able to repair i9300,please Z3X team on next update i9300 repair imei is a must with no bugs...:p |
no any bug with i9300. samsung have add new type of security. so you can do this now with new version. patching firmware and uploading patch to support - this method of monkey. we working on real professiaon solutions. |
can you upload patch to support ??? like nspro? meybe before you release good update?:) |
Blang just said it, patching is a monkey solution. Just wait for the real thing, you won't be dissapointed. |
we are waiting update ... |
