02-04-2014, 17:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Germany
Member: 396421 Status: Offline Thanks Meter: 87 | i9300 imei repair without lose signal The way is, as far as i understood correct, is to generate a file in efs, which will generate automatically valid imei certficate after each update. z3x team, now it is your turn, to find a way, how to do this. br |
The Following User Says Thank You to huzein For This Useful Post: |
02-04-2014, 18:28 | #2 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | i got the info that after the release of Android 4.3 it is possible to repair the IMEI and to repair network in this way that future updates will not cause network problems. The way is, as far as i understood correct, to generate a file in efs, which will generate automatically a valid imei certficate after each update. br huzein |
02-05-2014, 07:26 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | The Z3x latest Samsung tool(s) for sure remake IMEI + SN + Product code correct ( in EFS ) for i9300 - tested after many eMMC replacement ( with empty ones or resurected ) and phone(s) can be updated without ANY issues. Just only one problem was appear - there sometime 4.0.4 do not work correct after repair - must be 4.1.2 or later ... anyway - who care about old versions. |
02-17-2014, 21:07 | #6 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | i repaired network on a i9300 based on android 4.3 and i had IMEI CERTI: PASS and so signal. then i flashed the phone with a newer version and IMEI CERTI became FAIL, so signal again lost. It's a pity. Somehow it must be possible to repair the IMEI / network whatever that after updates the phone still gets signal... |
