11-12-2014, 02:02 | #1 (permalink) | ||
Freak Poster Join Date: May 2014 Location: Anywhere
Member: 2182001 Status: Offline Thanks Meter: 52 | I9300 No 3g after repair imei Reset efs + Cert Quote:
11-12-2014, 06:01 | #4 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote: | |
The Following User Says Thank You to debeliamark For This Useful Post: |
11-12-2014, 21:11 | #8 (permalink) |
Member: 2182001 Status: Offline Thanks Meter: 52 | Thanks for the reply master but I have little doubt. The second logic before the change, worked perfectly! being that I have worked on two different cards but show the same identical problem, I am easily deduce that the program fails to properly repair the network, in the case how can I check if the patch actually works to the network? thanks again |
11-13-2014, 08:07 | #9 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Lahore
Member: 2093017 Status: Offline Sonork: 100.1650959 Thanks Meter: 117 | if it,s software problem then it,s recoverd after repair network.you try all thing,s in software and i think none of work because it,s not software common sense bro |
11-13-2014, 13:13 | #10 (permalink) | |
Member: 2182001 Status: Offline Thanks Meter: 52 | I reflesh an 'other efs from a working phone with working imei, after doing so I tried to be the way of the cert that the repair classic but .... Quote:
