07-31-2013, 19:58 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 74258 Status: Offline Thanks Meter: 36 | t859 unlocking error how do i root it? see log Selected model: T859 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SGH-T859 Android version: 3.2 Product code: SGH-T859UWBTMB Phone version: T859UVKJ3 PDA version: T859UVKJ3_Demo CSC version: T859TMBKJ3 IMEI: 358379040146603 Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.15.2 |
08-02-2013, 10:43 | #2 (permalink) |
No Life Poster Join Date: Jun 2003 Location: kinshasa, D.R.C. Age: 59
Member: 31246 Status: Offline Thanks Meter: 54 | how to root samsung t859 for unlock how to root your samsung t859 download thise file and unzip in a folder 4shared.com - free file sharing and storage - Login [Step:] 1.Power On phone in download Mode by press. 2.Hold the Vol Down button (the left Volume button) and then hold the Power button as well. 3.Press the Vol Up button (the right Volume button) to select Downloading mode. 4.open Odin V1.85 and select file in pda recovery.tar.md5. 5.connect phone and click on start and wait for finish. 6.Disconnect your USB cable 7.On your device, turn off USB Debugging by going to Settings>Applications>Development and unchecking USB debugging Plug your USB cable back in 8.On your computer, go to the same root folder as before and transfer the zip file labeled “GalaxyTabHacks.com_SuperUser.zip” to your device. Don’t put it inside any folder. Confirm that it was transferred by clicking inside the device folder Power off the device by holding the power button and selecting Power off 10.Put the device into Recovery mode Hold the Vol Down button (the left Volume button) and then hold the Power button as well. Keep holding until you see two icons. First you’ll see the Samsung Galaxy Tab 10.1 logo and then the icons will show up. Let go. 11.Press the Vol Down button (the left Volume button) to highlight the left icon. 12.Press the Vol Up button (the right Volume button) to select Recovery mode. 13.You should see that you are in ClockworkMod Recovery. If not, start over 14.Use the volume buttons to highlight “Install zip from SD card” and hit the Power button to select it. 15.Use the volume buttons to highlight “Choose zip from SD card” and hit the Power button to select it. 16.Use the volume buttons to highlight “GalaxyTabHacks.com_SuperUser.zip” and hit the Power button to select it. 17.Use the volume buttons to highlight “Yes – Install…” and hit the Power button to select it. 18.When it finishes, the last line should say “Install from sdcard complete.” 19.Use the volume buttons to highlight “*****Go Back*****” and hit the Power button to select it. 20.Hit the Power button to select “reboot system now” 21.Your device will reboot You’re now rooted! Then unlock it |
The Following User Says Thank You to NiceLys For This Useful Post: |
08-02-2013, 11:22 | #3 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Quote:
Br, | |
08-03-2013, 08:51 | #4 (permalink) |
Member: 31246 Status: Offline Thanks Meter: 54 | download it here, i uploaded again, if not found contact me on messenger : 4shared.com - free file sharing and storage - Login |
08-03-2013, 09:16 | #5 (permalink) |
Member: 31246 Status: Offline Thanks Meter: 54 | download it here : root_samsung_t859 - Download - 4shared or root_samsung_t859_1 - Download - 4shared |
