11-14-2013, 14:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 49
Member: 139880 Status: Offline Sonork: 1678615 Thanks Meter: 6 | i9300non change imei samsung original Selected model: I9100 Selected port: COM1 Porta di comunicazione Selected port speed: 115200 Reading phone info... Model: GT-I9300 Android version: 4.0.4 Product code: Not Active Phone version: I9300XXLE8 PDA version: I9300XXALE8 CSC version: I9300ITVALE7 IMEI: 004999010640000 Phone S/N: 00000000000 Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Checking phone at COM1 No answer from phone Done with Samsung Tool v.16.1 Done with Samsung Tool v.16.1 |
11-14-2013, 14:57 | #3 (permalink) |
Freak Poster Join Date: Sep 2011 Location: venezuela Age: 37
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | amm did you..?? hey men.. did you used *#9090# and pressed option 2.. and restart phone again?? i bet you dont... after that, connect it to c3300k uart cable... BR.. |
11-14-2013, 15:36 | #5 (permalink) |
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | ammm with this I9300XXLE8 (the one you´re using) never had this problem.. try to upgrade to 4.1.2 using this pda I9300XXELKC_I9300OXXELK4_I9300XXELKC_HOME.md5 (search it on google of course) is the one i use for repairing (when errors appears)... and tell me how it went |
11-15-2013, 14:26 | #7 (permalink) |
Member: 139880 Status: Offline Sonork: 1678615 Thanks Meter: 6 | tried with the firmware but nothing to do, here is the log Selected model: I9100 Selected port: COM1 Porta di comunicazione Selected port speed: 115200 Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: Not Active Phone version: I9300XXELKC PDA version: I9300XXELKC CSC version: I9300OXXELK4 IMEI: 004999010640000 Phone S/N: 00000000000 Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Checking phone at COM1 Done with Samsung Tool v.16.1 |
11-15-2013, 14:37 | #8 (permalink) |
Member: 1656305 Status: Offline Sonork: 100.1624503 Thanks Meter: 48 | Are you sure that the z3x com port is com1? If the answer is Yes.. Change it to an upper comport (like com4, or the nearest available) and why are you selecting i9100? Use i9300 instead.. Check all that men.. Another comport and select the right model.. (Remember to restart the device again after *#9090# selection..) |
11-15-2013, 14:46 | #10 (permalink) |
Member: 139880 Status: Offline Sonork: 1678615 Thanks Meter: 6 | selection * # 9090 * port, etc.. made phone rebooted, I selected i9100 model as a guide and I have always enjoyed it, and proma this time I can not change it |
11-15-2013, 15:20 | #11 (permalink) |
Member: 139880 Status: Offline Sonork: 1678615 Thanks Meter: 6 | now wrote imei, but not entre the net ...... Selected model: I9100 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9300 Android version: 4.1.2 Product code: Not Active Phone version: I9300XXELKC PDA version: I9300XXELKC CSC version: I9300OXXELK4 IMEI: 004999010640000 Phone S/N: 00000000000 Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Checking phone at COM13 OK Reading phone info... Model: GT-I9300 Country code: ITV Cal date: - Factory SW: I9300XXELKC Unique number: CVTF1252018B46F Memory phone: - Software version: IMEI: Product code: Bypass MSL... OK Repairing IMEI... OK Repair done Reseting... OK Done with Samsung Tool v.16.1 |
11-15-2013, 21:11 | #13 (permalink) |
Member: 139880 Status: Offline Sonork: 1678615 Thanks Meter: 6 | I also tried a repair efs but nothing, I read that the problem was caused after the firmware is loaded xxemg4 that changes the location of the folder efs |
11-16-2013, 13:14 | #14 (permalink) |
Member: 139880 Status: Offline Sonork: 1678615 Thanks Meter: 6 | I used the patch ariza bill, but the recovery has written the modem firmware and started working again, here's the log: Model: GT-I9300 Android version: 4.1.2 Product code: Not Active Phone version: ARIZA_V[0.4] PDA version: I9300XXELKC CSC version: I9300OXXELK4 IMEI: 352993051995504 Phone S/N: 00000000000 Checking Super user right... true Reading data from phone... OK Writing data to phone... OK Rebooting phone... OK Checking phone at COM13 OK Reading phone info... Model: GT-I9300 Country code: CYO Cal date: - Factory SW: I9300XXELKC Unique number: CVTF1252018B46F Memory phone: - Software version: IMEI: Product code: Bypass MSL... OK Repairing IMEI... OK Repair done Reseting... OK Done with Samsung Tool v.16.1 Done with Samsung Tool v.16.1 |
