11-03-2015, 18:46 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | i9305 imei 01 Selected model: I9305 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9305 Android version: 4.3 Product code: Not Active Phone version: I9305XXUEMK1 PDA version: I9305XXUEMKC CSC version: I9305XEFEMK1 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM13 Detected ID: 00000FE6 (SURF9615) SW Version: M9615ACEHWMAZD179599 Reading ESN... OK Backuping RFNV... error (0) Done with Samsung Tool v.19.0 Selected model: I9305 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9305 Android version: 4.3 Product code: Not Active Phone version: I9305XXUEMK1 PDA version: I9305XXUEMKC CSC version: I9305XEFEMK1 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM13 Detected ID: 00000FE6 (SURF9615) SW Version: M9615ACEHWMAZD179599 Reading ESN... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Writing data to phone... error Done with Samsung Tool v.19.0 Selected model: I9305 Selected port: COM209 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9305 Android version: 4.3 Product code: Not Active Phone version: I9305XXUEMK1 PDA version: I9305XXUEMKC CSC version: I9305XEFEMK1 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM209 No answer from phone Done with Samsung Tool v.19.0 Selected model: I9305 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9305 Android version: 4.3 Product code: Not Active Phone version: I9305XXUEMK1 PDA version: I9305XXUEMKC CSC version: I9305XEFEMK1 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM13 Detected ID: 00000FE6 (SURF9615) SW Version: M9615ACEHWMAZD179599 Reading ESN... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Writing data to phone... error Done with Samsung Tool v.19.0 i av tried to with samsung tool pro latest version without success |
The Following 2 Users Say Thank You to hippolyte85 For This Useful Post: |
11-03-2015, 18:55 | #2 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | here with samsung tool pro REPAIR INSTRUCTIONS: Activate Diagnostic Port: 1. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 2. Press 'Activate Diag' button. Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Fill values what you need to repair. 10. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 5. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. To use 'Auto backup/restore QCN' function (recommended): Type *#0808# and select 'DM+MODEM+ADB'. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function. Or you can disable this function and use ADB only. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Choose diagnostic port in port settings if 'Auto backup/restore QCN' is not skipped. 6. Press 'Wipe EFS/NVM' button. Operation: Repair Selected model: GT-I9305 Selected port: COM209 SAMSUNG Mobile USB Serial Port Software version: 23.2 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9305 Android version: 4.3 Product code: Not Active Phone version: I9305XXUEMK1 PDA version: I9305XXUEMKC CSC version: I9305XEFEMK1 CSC country code: France CSC sales code: XEF HW version: Not Acti Phone S/N: Modem board: MDM9215M RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... OK Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.23.2 but still imei/01 |
