08-20-2013, 23:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: GB Age: 54
Member: 24791 Status: Offline Thanks Meter: 35 | i9305 no network after imei repair will this stop it from working i have tried to write new s/n and says all ok but after checking it is still 0000000000 |
08-21-2013, 11:41 | #4 (permalink) |
Member: 24791 Status: Offline Thanks Meter: 35 | tried from another handset and says Selected model: I9305 Selected port: COM3 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Checking phone at COM3 Repairing SN... OK Reseting... OK Repair done Done with Samsung Tool v.15.3 but still S/N:0000000000 |
08-21-2013, 21:09 | #7 (permalink) |
Member: 24791 Status: Offline Thanks Meter: 35 | if you have damaged modem/EFS(IMEI:null/null): 1. Phone must be powered on. 2. Enable "USB debugging" in "Settings"-"Developer options". 3. Type *#7284# and choose Modem for USB and PDA for UART options. 4. Press "Quallcomm USB settings" and select "DM+MODEM+ADB". 5. Connect phone to USB cable. 6. Select Diagnostic port in Port settings. 7. Press "Repair" button. 8. In opened window check "Repair EFS /Baseband", fill and check fields what you need to repair. 9. Press "OK" if the software can't root the phone automatically, then you must root your device manually. But i get this Selected model: I9305 Selected port: COM3 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.15.3 Done with Samsung Tool v.15.3 Would be nice to get support from the authors |
