12-28-2012, 22:32 | #1 (permalink) |
Temporary banned !! Join Date: Aug 2007 Location: Austria (Linz)
Member: 568521 Status: Offline Thanks Meter: 240 | I9305 successfully unlocked Selected port: COM22 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD1795 Done with Samsung Tool v.13.7 Selected model: I9305 Selected port: COM22 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD1795 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.13.7 Done with Samsung Tool v.13.7 |
The Following 3 Users Say Thank You to sharef For This Useful Post: |
03-27-2013, 15:39 | #6 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1693369 Status: Offline Thanks Meter: 25 | Saturday, January 5, 2013 Samsung Galaxy SIII i9305 Unlock Scessfully In Z3X Posted by Golam Maula Dolar Labels: Z3X Email ThisBlogThis!Share to TwitterShare to Facebook How To Unlock Samsung Galaxy S3 i9305 Phone In or Using Z3X If You Have A Samsung Galaxy S3 i9305 Locked Phone. Then You Can Unlock If Using Your Z3X Tool (If Have!!!). It's So Easy To Do It... 1st Method (If You Have Not Update Samsung Tool Software), 1st type *#7284# on the phone and select UART->MODEM, USB ->PDA Then tap "Save and Reset" 2nd type *#9090# on the phone and select DM over UART then power off the phone. Connect the phone to uart RH-45 cable and power on the phone 3rd with Z3X Samsung Tool chose T-989 model and press Unlock button. Then Your Phone Unlock Done!!!!!!!!!!!!!! 2nd Method (If You Have Latest Z3X Samsung Tool Software) 1st press *#7284# make sure u choose PDA both uart and usb then press Qualcomm USB settings choose DM+MODEM+ADB then press ok wait till drivers install. 2nd use USB cable and run Samsung Tool V13.3 or Any Update, then choose i9305 model and correct Com Port And press unlock Reading phone info... Build: M9615ACEHWMAZD1795 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done |
The Following User Says Thank You to mso1328 For This Useful Post: |
10-17-2015, 13:01 | #7 (permalink) |
Junior Member Join Date: May 2015
Member: 2399885 Status: Offline Thanks Meter: 0 | UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N900R4 Selected port: COM15 SAMSUNG Mobile USB Serial Port , Software version: 20.5 Reading phone info... Reading IMEI... OK IMEI: 990004340995871 Reading security... new type Bypassing... error Done with Samsung Tool v.20.5 help.... |
