08-11-2015, 00:33 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | i9500 imei null no solution writing cert or imei i get error REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Fill values what you need to repair. 5. Press 'Repair' button. 6. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 7. Press 'Disable Factory Mode' or 'Patch Certificate' if needed. Operation: Repair Selected model: GT-I9500 Software version: 22.0 Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 5.0.1 Product code: Phone version: PDA version: I9500UBUHOE1 CSC version: I9500UUBHOE1 CSC country code: TRINIDAD AND TOBAGO CSC sales code: TTT HW version: Phone S/N: RV1D95TZ1TB Modem board: RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... error Done with Samsung Tool PRO v.22.0 i tried write modem with odin without succes any advice will be great |
The Following User Says Thank You to denisirias For This Useful Post: |
08-11-2015, 00:47 | #2 (permalink) |
No Life Poster Join Date: Sep 2014 Age: 46
Member: 2260435 Status: Offline Thanks Meter: 118 | First of all Download this stock firmware I9500UBUGNJ1 and flash with Odin. After that, I like to hard reset just to be sure. Null must gone now. Then wipe EFS and restart device for imei repair. Good luck Enviado desde mi SM-N910T mediante Tapatalk |
The Following User Says Thank You to myciviczc For This Useful Post: |
08-11-2015, 19:39 | #5 (permalink) |
Member: 2260435 Status: Offline Thanks Meter: 118 | There is another firmware for Nulls but I don't have it. Another sugestión, test disconnecting simcard reader and charging flex cable Enviado desde mi SM-N910T mediante Tapatalk |
