09-03-2014, 23:02 | #2 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Barcelona, Spain Age: 39
Member: 1894707 Status: Offline Sonork: 100.1658432 Thanks Meter: 51 | 1. Try resetting phone to factory settings, using recovery mode -- Factory Reset -- Delete Cache -- If possible, clean dalvik cache If not working good again, 1. Check if IMEI is good 2. Check if baseband is good 3. Check if serial number is good 4. Try downgrading the phone to 4.1.2 and check again If not repaired again, there may be some hardware fault |
09-04-2014, 10:41 | #3 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: HGJIKL
Member: 1360208 Status: Offline Thanks Meter: 133 | Quote:
becaz some days ago,i downgraded one n7100 from 4.4.2 to 4.1.2 and phone stuck with out imei and baseband.so i sent it to samsung centre for fix. | |
09-04-2014, 14:02 | #4 (permalink) |
Member: 1894707 Status: Offline Sonork: 100.1658432 Thanks Meter: 51 | You can always Downgrade 19505 to 4.1.2. I tested it personally. But make sure the ROM you flash, is for i9505 and not any other |
