01-24-2014, 01:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | i9505 change imei failed with 16.9 1. Phone must be powered on. if you are using micro-uart cable: 2. Type *#7284# and choose Modem for UART options. 3. Type *#9090# and choose DM over UART. 4. Select correct COM port in Port settings, connect phone to UART cable. if you are using micro-USB cable: 2. Type *#7284# and choose PDA for UART options. 3. Type *#9090# and choose DM\DUM over HS-USB. 4. Select Diagnostic port in Port settings, connect phone to USB cable. The phone is on new bootloader, i have downgraded to UBMEA (4.2.2), the software say me: Selected model: I9505 Selected port: COM113 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Checking phone at COM113 Repairing IMEI... OK Reseting... OK Repair done Done with Samsung Tool v.16.9 But phone imei remain same... Any idea to solve it? I have tried to set CP on *#0808#, to use uart and usb method, but both have failed... |
