11-08-2013, 10:08 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | I9505 flashing error pls help me all user and z3x team thanks Here log Code: Selected model: I9505 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x91707784 Searching USB Flash Interface... not found Done with Samsung Tool v.16.1 Selected model: I9505 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x91707784 Searching USB Flash Interface... detected COM90 Setup connection... Error Done with Samsung Tool v.16.1 Selected model: I9505 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x91707784 Searching USB Flash Interface... detected COM90 Setup connection... Error Done with Samsung Tool v.16.1 Selected model: I9505 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x98F7BEF8 Searching USB Flash Interface... detected COM36 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I9505_8-11-2013_15-51-31.pit Sending sbl2.mbn... OK Sending sbl3.mbn... OK Sending rpm.mbn... OK Sending aboot.mbn... Error Done with Samsung Tool v.16.1 Selected model: I9505 Selected port: COM6 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x9EEDBAC4 Searching USB Flash Interface... detected COM36 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I9505_8-11-2013_16-0-31.pit Sending boot.img... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Sending modem.bin... OK Sending NON-HLOS.bin... OK Sending recovery.img... OK Sending system.img.ext4... Error Done with Samsung Tool v.16.1 |
11-08-2013, 10:12 | #2 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | bro flash via odin if still error while flashing you try other firmware |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
11-25-2013, 15:36 | #4 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 255328 Status: Offline Thanks Meter: 25 | Samsung i9505 full flash Samsung i9505 error in flashing but now i am slove proble flash with odin not use pit file or not use bootloader only ues 3 file pda+phone+csc yor phone alive now |
The Following 2 Users Say Thank You to DEMA125 For This Useful Post: |
04-05-2015, 07:39 | #7 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Ghana Akatsi Age: 40
Member: 853308 Status: Offline Thanks Meter: 61 | Selected model: I537 Selected port: COM15 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x8F7A7E40 Searching USB Flash Interface... detected COM148 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I537_5-4-2015_6-31-3.pit Sending boot.img... OK Sending recovery.img... OK Sending persdata.img.ext4... OK Sending system.img.ext4... Error Done with Samsung Tool v.19.1 Done with Samsung Tool v.19.1 |
04-06-2015, 14:16 | #8 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
try use more high firmware version. | |
The Following User Says Thank You to blang For This Useful Post: |
06-05-2015, 12:54 | #9 (permalink) | |
Junior Member Join Date: Feb 2012
Member: 1722038 Status: Offline Thanks Meter: 0 | Quote:
09-28-2016, 15:23 | #11 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 52
Member: 85182 Status: Offline Sonork: 1593854 Thanks Meter: 42 | No luck for me: ID:0/016> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> AP_I9505XXUHOA7_CL3996895_QB3867680_REV06_user_low _ship_MULTI_CERT_.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:1/003> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CP_I9505XXUHOA7_CL3996895_QB3867680_REV06_user_low _ship_MULTI_CERT.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> CSC_OXA_I9505OXAHOA7_CL3996895_QB3867680_REV06_use r_low_ship_MULTI_CERT.tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/016> Odin engine v(ID:3.1005).. <ID:1/003> Odin engine v(ID:3.1005).. <ID:0/016> File analysis.. <ID:1/003> File analysis.. <ID:1/003> SetupConnection.. <ID:0/016> SetupConnection.. <ID:1/003> Initialzation.. <ID:1/003> Set PIT file.. <ID:1/003> DO NOT TURN OFF TARGET!! <ID:1/003> Get PIT for mapping.. <ID:1/003> Firmware update start.. <ID:1/003> SingleDownload. <ID:1/003> boot.img <ID:1/003> NAND Write Start!! <ID:1/003> persdata.img.ext4 <ID:1/003> Complete(Write) operation failed. <ID:1/003> Removed!! |
The Following User Says Thank You to zipikiki For This Useful Post: |
