03-21-2014, 13:11 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 45
Member: 49428 Status: Offline Thanks Meter: 45 | -= i9505 help with IMEI & UART mode problems... Phone is i9505 with 4.4.2 kitkat installed, using official samsung fw Phone was given to me lost imei & screen had been replaced before so the original IMEI is gone. I have another that is broken motherboard and was replacing with the same IMEI. I used z3x box and UART c3300k cable. I did : Press *#7284# and select "Modem" (Only show one option interface "UART") *default setting: "PDA" - Press *#9090# and select "4 - DM over UART" Reprogrammed the new IMEI and phone accepts. Reboot phone insert sim, get Network Not Available or something... Basically cannot connect to network. After playing with APN settings etc... I decided to use repair EFS and Mobile Network option using microUSB cable. Again I *#7284# and *#9090# changed everything to USB. Completed repair everything says ok. Reboot phone... now MISSING IMEI NOW THIS PART IS WHERE I HAVE PROBLEM: *#7284# no longer goes to UART menu. So I choose *#9090#... I change to DM over UART. I enter imei in repair mode... rewrite imei success. Reboot phone... Phone still no IMEI. My 1st question: is the IMEI specific to MNC-MCC? I realize that doesn't change. is the IMEI specific to serial? My 2nd question: how come I cannot use *#7284# <--- when I do that nothing happens. I hit send and network error. I always hate repair IMEI on samsung... rediculous... |
03-21-2014, 14:09 | #2 (permalink) |
Member: 49428 Status: Offline Thanks Meter: 45 | Selected model: I9505 Selected port: COM4 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9505 Android version: 4.4.2 Product code: Not Active Phone version: I9505XXUFNBE PDA version: I9505XXUFNBE CSC version: I9505OXAFNB8 IMEI: 35684505610XXXX Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Reseting EFS... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... OK Repairing... OK Disabling TEST mode... OK Reseting... OK Repair done Done with Samsung Tool v.17.0 =-=-=-=-=-=-=- OK i got the IMEI programmed but still no network :\ what could be wrong? |
03-25-2014, 13:56 | #5 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 564049 Status: Offline Thanks Meter: 100 | Quote:
03-26-2014, 11:11 | #7 (permalink) |
Freak Poster Join Date: Apr 2010 Location: WESTJAVA - INDONESIA
Member: 1278042 Status: Offline Sonork: 100.1656045 Thanks Meter: 117 | search in google CF-Auto-Root-jflte-jfltexx-gti9505.tar.md5 and I9505_4.3patch4unlock.tar and follow this instruction Flash CF-Auto-Root-jflte-jfltexx-gti9505.tar.md5 and flash I9505_4.3patch4unlock.tar Unlock I9505 only with usb cable and z3x box you need to put phone in this mode: select *#9090# *1 dm dun over hs usb *#0808# *cp ap *dm+modem+adb Reboot phone and conect to usb open Samsung tool enter to phone *#0808# *cp select CP and press OK wait install Qualcoom driver and select Qualcoom port. press unlock button. All works. |
03-26-2014, 11:48 | #8 (permalink) | |
Member: 49428 Status: Offline Thanks Meter: 45 | Quote:
So you are saying downgrade from 4.4.1 to 4.3 now right? Have u tested downgrade? | |
04-22-2014, 17:22 | #10 (permalink) |
No Life Poster Join Date: Feb 2013
Member: 1890459 Status: Offline Sonork: 100.1627340 Thanks Meter: 149 | Selected model: I9505 Selected port: COM8 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9505 Android version: 4.3 Product code: Not Active Phone version: I9505XXUEMKF PDA version: I9505XXUEMKF CSC version: Unknown IMEI: null spent 27m Phone S/N: RF8F200XZ3N Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM8 Backuping NVM... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... OK Repairing... OK Checking phone at COM8 Restoring NVM... OK Reseting... OK Repair done Done with Samsung Tool v.17.2 Selected model: I9505 Selected port: COM8 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: GT-I9505 Android version: 4.3 Product code: Not Active Phone version: I9505XXUEMKF PDA version: I9505XXUEMKF CSC version: I9505ATOEMK5 IMEI: 359484024720XXX Phone S/N: RF8F200XZ3N Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM8 Backuping NVM... OK Writing data to phone... OK Reseting EFS... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... OK Repairing... OK Disabling TEST mode... OK Checking phone at COM8 Restoring NVM... OK Reseting... OK Repair done Done with Samsung Tool v.17.2 Its work good |
04-22-2014, 19:09 | #11 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Try this write efs ,flash a file i9505 file for unlcok is a modem patch for new security try unlock if is nasesery try again imei repair and post result If i helped you press thanks button ↓ |
04-08-2015, 00:20 | #12 (permalink) |
Junior Member Join Date: Oct 2008
Member: 884387 Status: Offline Thanks Meter: 0 | Welcome . M you have had the same problem. I have done as described , and now there was problme with IMEI . Shows null / null Received any new software, root , tuning IMEI and still the same problem. Z3x Box . Loading efs too . |
