06-02-2013, 16:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | i9505 unlock ok but can not unlock Selected port: COM125 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Done with Samsung Tool v.14.6 Selected model: I9505 Selected port: COM125 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M9615A-CEFWTAZM-4.0.17062 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.14.6 Done with Samsung Tool v.14.6 try many time but can not sucess. all time software show phone unlock but when i insert sim phone ask net lock code solution need........................ |
06-02-2013, 18:50 | #8 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 969318 Status: Offline Thanks Meter: 82 | Try This: How to: - Cable UART C3300K - Select com port box in ST software - Press *#7284# and select "Modem" (Only show one option interface "UART") *default setting: "PDA" - Press *#9090# and select "4 - DM over UART" *default setting: "DM/DUN over HS-USB" - Press "Unlock" |
06-04-2013, 07:18 | #9 (permalink) | |
Member: 1150957 Status: Offline Thanks Meter: 60 | Quote:
When i select *#7284# and select "Modem" its working But when press *#9090# and select "4 DM over UART " Phone restart but can not change to DM over UART, Automaticly Select default setting: "DM/DUN over HS-USB Whats problem........... | |
The Following User Says Thank You to brokendreem For This Useful Post: |
06-04-2013, 08:48 | #12 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | brother still not solved your problem? so many users already done unlock just look these links http://forum.gsmhosting.com/vbb/f453...-done-1664869/ http://forum.gsmhosting.com/vbb/f453...4-4-a-1656323/ http://forum.gsmhosting.com/vbb/f453...t-sec-1666730/ what about read code did you try mannul unlock? |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
