01-01-2014, 03:33 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Algeria
Member: 918393 Status: Offline Thanks Meter: 515 | I9506 (imei:Null/NULL & Unknown Baseband) Successfully Repaired i've successfully repaired 2 (GALAXY S4 ADVANCE LTE) i9506 who have Problem (imei:null/null & Unknown Baseband) And Without support From Z3X-Team from 15 days ago, and voila my posts: http://forum.gsmhosting.com/vbb/f453...twork-1753096/ http://forum.gsmhosting.com/vbb/f453...-help-1757672/ http://forum.gsmhosting.com/vbb/f453...d-z3x-1759357/ i've created a 100/100 working EFS file , after i flashed to those Phones Now Baseband Restored Succsefully , imei corrupted showed as /1 that's normal becasue this EFS parametres not matching to this phone Now Repair Original IMEI & enjoy Note: When Flashing The EFS File you done with an error (Auth-Fail) D'ont Worry, The Phone will 100/100 Repaired. Requirements: Odin3 v3.0 Root Acsses Android 4.2.2 For Android 4.3 i will try & inform You about result If Any One Need This File i will upload it. Last edited by m-fodil; 01-01-2014 at 03:39. |
The Following 4 Users Say Thank You to m-fodil For This Useful Post: |
01-01-2014, 20:07 | #5 (permalink) |
Member: 918393 Status: Offline Thanks Meter: 515 | Other Thing: This EFS file also repair: (Not Registred On Network) & (No Network) Tested By Me & 100/100 Working Good Luck For All |
The Following User Says Thank You to m-fodil For This Useful Post: |
01-02-2014, 11:38 | #7 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1907040 Status: Offline Thanks Meter: 4 | after flash this file using Odin3 V3.07 in the Modem feild it said Fail in the end even in PDA feild too. and after power on the phone the Imei change to (/1) i do a succesful repair with Z3X but after that it still the same problem no network register and when i go to network search i Got the whole Operators i chose my network sim it start searching a while but in the end it said unable to connect, try later. Please what i'm doing wrong? M-fodil help me |
01-03-2014, 02:39 | #8 (permalink) | |
Member: 918393 Status: Offline Thanks Meter: 515 | Quote:
folow this: 1- choose GSM in network settings 2- turn airplane mode 3- call 112 (radio automatically activated) & dont interupt, let phone end call itself 4- power off the phone 5- power on again , end now let phone find the network itself , for me it took 2 hours , also my freind it took it about 6 or 7 hours try this & let me know good luck | |
03-01-2014, 17:30 | #13 (permalink) | |
Junior Member Join Date: Mar 2014
Member: 2138516 Status: Offline Thanks Meter: 1 | Quote:
