12-29-2012, 13:18 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Sweden
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | i997 ifuse 4g 4.0.4 wont unlock plz help logs Selected model: I997 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SGH-I997 Android version: 4.0.4 Product code: SGH-I997ZKZATT Phone version: I997UCLB3 PDA version: Unknown CSC version: Unknown IMEI: 355815042944951 Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.0.4 Done with Samsung Tool v.13.7 |
12-29-2012, 13:24 | #2 (permalink) | |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Quote:
Br Vikash | |
12-29-2012, 17:16 | #4 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 304933 Status: Offline Sonork: 100.1618191 Thanks Meter: 49 | Selected model: I997 Selected port: COM73 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SGH-I997 Android version: 4.1.2 Product code: SGH-I997ZKARWC Phone version: I997UCKL2 PDA version: Unknown CSC version: Unknown IMEI: 358039040235513 Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.1.2 Done with Samsung Tool v.13.7 i have same problem ple guide me how to root |
12-29-2012, 17:43 | #5 (permalink) |
Member: 304933 Status: Offline Sonork: 100.1618191 Thanks Meter: 49 | i root it but stand one sumsun g logo Steps to root Rogers Samsung Infuse 4G SGH-I997R Step 1: In the root directory of your phone create a new folder named Voodoo. Step 2: Create a sub-folder named disable-lagfix in that Voodoo folder. Step 3: Now switch off your phone and download a rooting package named Odin_Infused_Gingerbread_Kernel_v1.zip in your computer which will take about 8MB space. Step 4: After downloading extract the files by using any ZIP extractor software into a folder on your computer. Step 5: Now right click on the Odin3_v1.81.exe to run it as Administrator from the popup menu. Step 6: Via USB cable connect your device to your computer. Step 7: Turn on your device into a download mode pressing and holding the Volume Up and Volume Down buttons simultaneously. Step 8: ID:COM box in Odin3 must be highlighted in yellow. The COM number also visible in the box and if it is not highlighted then Odin3 has not detected your phone. Step 9: In the Odin3 click the PDA button. Step 10: Select PDA_Infused_Gingerbread_Kernel_v1.tar.md5 in the browser file dialog and then click on the start button. Step 11: The rooting will start and after its get completely installed, the device automatically gets rebooted. Step 12: Now detach your phone from computer and to verify the Superuser to check that your phone is rooted. Or install BusyBox app from the Android Market. |
The Following User Says Thank You to gsmsoftware77 For This Useful Post: |
12-30-2012, 07:59 | #8 (permalink) |
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | phone has super user icon it means it is rooted but getting error to unlock it logs Selected model: I997 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.13.7 Selected model: I997 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... not found Done with Samsung Tool v.13.7 Selected model: I997 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SGH-I997 Android version: 4.0.4 Product code: SGH-I997ZKZATT Phone version: I997UCLB3 PDA version: Unknown CSC version: Unknown IMEI: 355815042944951 Checking Super user right... false Rooting phone, please wait... error Not supported android version 4.0.4 Done with Samsung Tool v.13.7 |
12-30-2012, 16:03 | #11 (permalink) |
No Life Poster Join Date: May 2009 Age: 49
Member: 1027729 Status: Offline Thanks Meter: 97 | [ODIN][UCLB3] AT&T 2.3.6 Gingerbread with root and CWM recovery option - Infuse 4g - xda-developers root your phone and select t959v press read codes -------------------------- 30-12-2012_19-54-50 -------------------------- Selected model: T959V Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: SAMSUNG-SGH-I997 Android version: 2.3.6 Product code: SGH-I997ZKZATT Phone version: I997UCLB3 PDA version: I997UCLB3 CSC version: I997ATTLB3 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:00) Freeze/Master code: 29095720 NET lock: 73029074 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.13.7 |
12-31-2012, 09:32 | #14 (permalink) | |
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | Quote:
and i have android 4.0.4 where is z3x team to help users | |
