10-26-2012, 07:50 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Sweden
Member: 503620 Status: Offline Sonork: 1621694 Thanks Meter: 46 | i997 at&t after write this SGH-I997_I997UCLB3_UC_ATT firmware phone restarting i997 at&t after write this SGH-I997_I997UCLB3_UC_ATT firmware phone restarting need help its condition was no showing network bar after insert sim |
10-26-2012, 16:21 | #4 (permalink) |
Banned Join Date: Dec 2010
Member: 1478797 Status: Offline Sonork: antonio kerr Thanks Meter: 3 | Download Mode Method 1: - power down phone - insert your it work on the i997 Method 2: - shut down phone - remove SIM & SD - hold vol + / - - insert usb cable (while plugged into pc) - hit vol up to enter download mode - proceed to flashing via ODIN Updating to newest leak If you aren't using a .PIT file make sure "re-partition" is unchecked! - download the newest leak (of course) - extract the .tar file into an easy to find location - open ODIN as Admin - boot phone into dl mode - insert usb into phone - confirm ODIN says COM## - open your .tar file in the PDA tab - hit "Start" and let ODIN work its magic Once phone boots into recovery - select "wipe data/factory reset" - select "reboot device" and... VIOLA! You've officially updated to the newest leak! |
The Following User Says Thank You to antonio kerr For This Useful Post: |
