11-10-2011, 02:31 | #1 (permalink) |
Junior Member Join Date: Feb 2009 Location: colombia, cartago
Member: 968754 Status: Offline Thanks Meter: 0 | IMEI e2230 000000000000000 after unlock Selected model: E2230 Selected com port: COM7 Selected port speed: 921600 Phone Must be OFF Press * and connect phone by USB cable Connecting to Device ... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART Cable Deactivate MSL - fail Repair - fail Elapsed time: 51 second, sw see: 3.5.0029 after this I'll take the IMEI 000000000000000, try to write and gives me the same error (translated with google) |
11-10-2011, 16:21 | #2 (permalink) |
Member: 968754 Status: Offline Thanks Meter: 0 | Estado buscando en el foro y encontre que se le puede leer los codigos con la vercion 2G_tools_3.5.0022.exe y con el modelo e2330. estado intentando escribirle el imei original este mismo modelo pero se bloquea o no termina el proceso desde la vercion 2G_tools_3.5.0009.exe a 2G_tools_3.5.0029.exe. todavia necesito ayuda (traducido por google) |
11-10-2011, 16:29 | #3 (permalink) | |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | Quote:
The Following User Says Thank You to rahul_rocks3 For This Useful Post: |
11-10-2011, 17:03 | #4 (permalink) |
Member: 968754 Status: Offline Thanks Meter: 0 | look what I get: Selected model: E2230 Selected com port: COM7 Selected port speed: 460800 Phone Must be OFF Press * and connect phone by USB cable Connecting to Device ... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART Cable Deactivate MSL - fail Repair - fail Elapsed time: 36 second, sw see: 3.5.0029 |
11-10-2011, 17:08 | #5 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Lahore, Pakistan
Member: 454021 Status: Offline Thanks Meter: 57 | IMEI e2230 000000000000000 after unlock my dear unchek imei and customise ur phone done if not type ur phone imei number and then costomise ur phone its ok 100% regards faisal |
11-11-2011, 16:32 | #8 (permalink) |
No Life Poster Join Date: Jun 2002 Location: City
Member: 12663 Status: Offline Thanks Meter: 78 | Code: Selected model: E2230 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Timeout Read - fail Deactivate MSL - fail Read info - fail Elapsed time: 18 second, sw ver: 3.5.0029 Cant Unlock or Repair IMEI Tried with 3.5.0022 ->> 3.5.0029 Also with selecting 2232 or 2530 etc... |
12-01-2011, 00:49 | #12 (permalink) |
Freak Poster Join Date: Jun 2004 Location: POLAND & BELGIUM Age: 42
Member: 67785 Status: Offline Thanks Meter: 20 | E2230 repair procedure flash with HWK flasher in support bin.RD repair p3 flash rebulid imei button with hwk enter SN enter IMEI -Done after flash another flash from suport with language wester europe reparing flash have romania , rusian language this flash have french turkisch language E2230JVKC1_OJVKC1_RD.rar whay z3x have problem add line with manual flash support from hwk bin.rd long time nothing orginal flash samung in support !!! |
08-05-2012, 07:20 | #13 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Lahore
Member: 529487 Status: Offline Sonork: nennoo Thanks Meter: 42 | ------------------------------------------------------------------------------- Selected model: E2232 Selected com port: COM27 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Timeout Deactivate MSL - fail Repair - fail Elapsed time: 71 second, sw ver: 3.5.0038 |
09-17-2012, 23:09 | #14 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK Age: 44
Member: 232341 Status: Offline Thanks Meter: 55 | samsung e2230 locked to UK O2. Selected model: E2230 Selected com port: COM15 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Read info - fail Elapsed time: 23 second, sw ver: 3.5.0038 -------------------------------------------- then got 0000000000000. tried opt repair and customer repair, both failed. found out there was a trick that you can select e2350 to get it fixed and unlocked. Selected model: E2350 Selected com port: COM9 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Erasing ... OK Writing ... OK Repair OTP - ok Elapsed time: 19 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Selected model: E2350 Selected com port: COM9 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK Search diag port... OK (COM15) Phone SN: RUYB742175 Deactivate MSL - OK Phone OLD IMEI: 35704204120xxx/00 Repair - fail Elapsed time: 55 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Selected model: E2350 Selected com port: COM9 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK Search diag port... OK (COM15) Phone SN: RUYB742175 Deactivate MSL - OK Read - fail Calculated code please wait... Decrypted time: 33 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*66982895# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*32716538# this is Master(freeze) code Read info - ok Elapsed time: 92 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
10-24-2012, 13:58 | #15 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: TURKEY
Member: 1245396 Status: Offline Sonork: BR*BY*PROF*47*47* Thanks Meter: 109 | Quote:
select model e2330 new imei e2230 sn code repair otp repair custom change 000000 repair work zx3 | |
The Following User Says Thank You to RIDVAN4747 For This Useful Post: |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
