06-08-2017, 06:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | imei null Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N900 Software version: 28.2 Checking CERT file... Ok KEY ID: 0813 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-N900 Android version: 5.0 Product code: Phone version: PDA version: N900XXUEBNL8 CSC version: N900OXAEBNL8 CSC country code: Poland CSC sales code: XEO HW version: Phone SN: 00000000000 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking magic... SSNV not found Done with Samsung Tool PRO v.28.2 |
06-08-2017, 07:08 | #2 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N900 Software version: 28.2 Checking CERT file... Ok KEY ID: 0813 Waiting ADB device... Ok Reading phone info... Model: SM-N900 Android version: 5.0 Product code: Phone version: PDA version: N900XXUEBNL8 CSC version: N900OXAEBNL8 CSC country code: Poland CSC sales code: XEO HW version: Phone SN: RF1D98WVS3P Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking magic... Ok Running zTool, please wait... error (8) Done with Samsung Tool PRO v.28.2 |
