04-18-2017, 00:50 | #1 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2164073 Status: Offline Sonork: quantumunlock Thanks Meter: 0 | Imei repair g928t problem Reading phone info... Model: SM-G928T Android version: 6.0.1 Product code: SM-G928TZDETMB Phone version: G928TUVU4DQC2 PDA version: G928TUVU4DQC2 CSC version: G928TTMB4DQC2 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58G90B0GQD Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: 20150904 IMEI: Checking Super user right... true Reading NV data... error Done with Samsung Tool PRO v.28.1 The error in NV data reading happens in every function. PLS HELP |
04-21-2017, 05:01 | #3 (permalink) |
Member: 2164073 Status: Offline Sonork: quantumunlock Thanks Meter: 0 | Hi ltindi32, Thanks for the response. I can't seem to find just the modem for: G928TUVS4DPH2 Can you send me a link to just the modem. Which I am guessing I will flash with odin...after flashing and finished unlock and IMEI repair will I be able to upgrade the modem back to G928TUVU4DQC2 if so can you also provide me a link to that modem too. Thanks in advance, Quantum |
04-21-2017, 16:37 | #4 (permalink) | |
Freak Poster Join Date: Oct 2014 Location: puerto rico
Member: 2282504 Status: Offline Thanks Meter: 50 | Quote:
Flash modem in cp with odin and post the result. Do not remove the modems. They flashed them just as they are | |
The Following User Says Thank You to ltindi32 For This Useful Post: |
04-21-2017, 16:39 | #5 (permalink) | |
https://www.androidfilehost.com/?fid=312968873555012097 | |
04-23-2017, 04:51 | #6 (permalink) |
Member: 2164073 Status: Offline Sonork: quantumunlock Thanks Meter: 0 | Hi ltindi32, Okay tried first modem file - G928TUVS4DPH2 but stil getting the same error: Operation: Unlock Selected model: SM-G928T Software version: 28.1 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G928T Android version: 6.0.1 Product code: SM-G928TZDETMB Phone version: G928TUVS4DPH2 PDA version: G928TUVU4DQC2 CSC version: G928TTMB4DQC2 CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R58G90B0GQD Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-01-01 RF cal date: 20150904 IMEI: Checking Super user right... true Reading NV data... error Done with Samsung Tool PRO v.28.1 |
04-23-2017, 06:45 | #7 (permalink) |
Member: 2164073 Status: Offline Sonork: quantumunlock Thanks Meter: 0 | Hi ltindi32, Here are the results from the second combination file (flashed with ODIN AP). The phone opens to a Factory Binary screen and just stays there... Waiting ADB device... Ok Reading phone info... Model: SM-G928T Android version: 5.1.1 Product code: Phone version: PDA version: FA51_G928TUVU4APH2 CSC version: CSC country code: CSC sales code: HW version: Phone SN: R58G90B0GQD Chip name: EXYNOS7420 Modem board: RF cal date: IMEI: Checking Super user right... false Root your phone manually and then repeat Done with Samsung Tool PRO v.28.1 thanks, Quantum |
04-23-2017, 15:31 | #8 (permalink) | |
04-23-2017, 16:58 | #9 (permalink) |
Member: 2164073 Status: Offline Sonork: quantumunlock Thanks Meter: 0 | I don't have any access to do anything on the phone once the second combination has been flashed. It just opens to a screen that says binary factory. Any other suggestions? Quantum |
04-24-2017, 03:44 | #11 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Exactly! There could be damaged/missing efs/imei even before the modem downgrade or combi flash. Please fix those issues first before doing anything else. Flash back to stock UVU4DQC2 firmware, and do an UNLOCK only then post the log. |
04-24-2017, 05:25 | #12 (permalink) | |
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Actually, here are the correct steps. Flash it back to full stock (4-file): AP tab: Samsung_G928T_UVU4DQC2_v6.0.1_AP.TAR BL tab: Samsung_G928T_UVU4DQC2_v6.0.1_BL.TAR CP tab: Samsung_G928T_UVU4DQC2_v6.0.1_CP.TAR CS tab: Samsung_G928T_UVU4DQC2_v6.0.1_CS.TAR Enable OEM Unlock then flash only these files: AP tab: Samsung_G928T_UVU3DPG1_v6.0.1_Eng_Boot_Only.TAR CP tab: Samsung_G928T_UVU4DPH2_v6.0.1_CP.TAR This will give you the correct combination for repair, by enabling both root and modem access without tripping Knox. Good luck! BillA Cuz sharing is caring Last edited by BillA; 04-24-2017 at 05:34. | |
04-23-2018, 18:57 | #13 (permalink) |
Major Poster Join Date: Sep 2012 Location: zacatecas mexico
Member: 1812133 Status: Offline Thanks Meter: 18 | Actually, here are the correct steps. Flash it back to full stock (4-file): AP tab: Samsung_G928T_UVU4DQC2_v6.0.1_AP.TAR BL tab: Samsung_G928T_UVU4DQC2_v6.0.1_BL.TAR CP tab: Samsung_G928T_UVU4DQC2_v6.0.1_CP.TAR CS tab: Samsung_G928T_UVU4DQC2_v6.0.1_CS.TAR Enable OEM Unlock then flash only these files: AP tab: Samsung_G928T_UVU3DPG1_v6.0.1_Eng_Boot_Only.TAR CP tab: Samsung_G928T_UVU4DPH2_v6.0.1_CP.TAR This will give you the correct combination for repair, by enabling both root and modem access without tripping Knox. hi can u help i need files i have same problem no imei and unknow baseband |
