03-19-2013, 18:32 | #7 (permalink) |
Junior Member Join Date: Jun 2007
Member: 520478 Status: Offline Thanks Meter: 3 | samsun c3262 simlock solution 10000% working use z3x box and c3262 rj45 cable use samsung tool14.1 switch off mobile and do operation read code |
The Following 2 Users Say Thank You to imraan1112000 For This Useful Post: |
06-13-2013, 08:35 | #8 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Apple Age: 35
Member: 1918158 Status: Offline Thanks Meter: 177 | Selected model: C3262 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Phone detected Switch phone in TAT mode... OK Reading phone info... OK Phone version: C3262DXMC1 CSC version: C3262OLAMB3 IMEI: 35401305426895 Phone SN: RZ1D14G2E7 Phone BT: 00:88:E5:61:A2:00 Bypass MSL... OK Reading codes... OK Freeze code: 21979310 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00012413 Phone lock: 00000000 Done with Samsung Tool v.14.1 |
10-04-2013, 16:12 | #10 (permalink) |
Freak Poster Join Date: Jul 2008 Location: ludhiana
Member: 818717 Status: Offline Sonork: [email protected] Thanks Meter: 81 | just use 14.9 download from support area 100% is working for all locks |
10-20-2013, 14:42 | #12 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1461689 Status: Offline Thanks Meter: 0 | thanks Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Phone detected Switch phone in TAT mode... OK Reading phone info... OK Phone version: C3262DDMA1 CSC version: C3262ODDLL2 IMEI: 35401305495746 Phone SN: RZ1D20H6KP Phone BT: 00:88:E5:6E:3A:B8 Bypass MSL... OK Reading codes... OK Freeze code: 81220290 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 89201392 Phone lock: 00000000 Done with Samsung Tool v.15.2 |
10-20-2013, 15:00 | #13 (permalink) |
Member: 1461689 Status: Offline Thanks Meter: 0 | Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Timeout Done with Samsung Tool v.15.2 Selected model: C3262 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 921600 Connect phone and press power button Phone detected Switch phone in TAT mode... OK Reading phone info... OK Phone version: C3262DDMA1 CSC version: C3262ODDLL2 IMEI: 35401305495746 Phone SN: RZ1D20H6KP Phone BT: 00:88:E5:6E:3A:B8 Bypass MSL... OK Reading codes... OK Freeze code: 81220290 NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 89201392 Phone lock: 00000000 Done with Samsung Tool v.15.2 |
