08-07-2017, 06:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | J111f unlock success without root 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 11111111 To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J111F Software version: 29.0 Searching Samsung modem... detected COM7 Reading phone info... OK Model: SM-J111F Version: J111FXXU0AQD2/J111FOLB0APL2/J111FXXU0AQC2/J111FXXU0AQD2 Product code: SM-J111FZWDXME Phone SN: RV8J41WAKDL IMEI: 357659083788663 Unique number: C8G0132A0425634 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:24) Freeze code: 40406381 NET lock: 80418425 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.0 |
