Old 08-02-2017, 02:28   #1 (permalink)
Member: 509870
Thanks Meter: 2
j120az unlock Binary 3?? possible?
hi guys, any way to unlock j120az binary 3? i tried on QE1 and QD2 and same error " please downgrade modem " ?
Old 08-02-2017, 02:36   #2 (permalink)
Member: 1135851
Just restore with Samsung sidesync and then activate oem and debuggin. Look for ENG boot and flash it install kingoroot APK and can take to 3 tries before root. Once root read codes or direct unlock. Hope ir helps
Enviado desde mi LG-H700 mediante Tapatalk
Old 08-02-2017, 02:40   #3 (permalink)
Member: 509870
Thanks Meter: 2
j120a eng boot will work? and im in QD2 can i root on that or do i have to flash the QE1?
Old 08-02-2017, 02:41   #4 (permalink)
Member: 1135851
On qd2 works
Old 08-02-2017, 02:41   #5 (permalink)
Member: 455304
Thanks Meter: 417
no need for all that just flash this modem and read code https://mega.nz/#!w8AgTTJY!ahPj1yr6h...zrn99ni3y7_IIU
The Following 2 Users Say Thank You to shawn4life For This Useful Post:
Old 08-02-2017, 02:43   #6 (permalink)
Member: 509870
Thanks Meter: 2
itll work with binary 3 j120az devices? i tried one earlier and it gave me Unkown baseband ?
Old 08-02-2017, 02:45   #7 (permalink)
Member: 509870
Thanks Meter: 2
i cant find j120az eng boot ?
Old 08-02-2017, 02:48   #8 (permalink)
Member: 455304
Thanks Meter: 417
just try it no unknown baseband
Old 08-02-2017, 02:49   #9 (permalink)
Member: 2395490
Thanks Meter: 515
Smile
http://forum.gsmhosting.com/vbb/f453...-root-2246812/
Old 08-02-2017, 02:51   #10 (permalink)
Member: 509870
Thanks Meter: 2
i have same one 31.1mb i put in cp and flashed and it gave me unkown baseband ealrier ???
Old 08-02-2017, 02:53   #11 (permalink)
Member: 509870
Thanks Meter: 2
Originally Posted by Alexandroid View Post
flash that in CP slot?
Old 08-02-2017, 02:55   #12 (permalink)
Member: 2395490
Thanks Meter: 515
Bro it is not the same just for tje size.
Put here your compilation. If it is 3AXXX you can unlock it with this modem
Old 11-18-2017, 05:31   #13 (permalink)
Member: 2645992
Sonork: yoslen2017
Hi friend it is very easy to read codes of any compilation without root, j120az to read codes , first flash factory binary qe1,active USB debugging and *#0808#,and open the ports as you know, used z3x software 29.8 and ready 100% tested, After flash last qd2 and qe1 whatever,greetings to all thank s.
The Following User Says Thank You to yoslen2017 For This Useful Post:
Page generated in 0.19467 seconds with 8 queries
