03-02-2016, 00:56 | #1 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1876037 Status: Offline Sonork: RG10 Thanks Meter: 1 | J120m reset frp error [ 3/1/2016 6:52:00 PM ] Setup connection... OK [ 3/1/2016 6:52:00 PM ] Reading PIT from phone... OK [ 3/1/2016 6:52:00 PM ] Searching FRP lock... OK [ 3/1/2016 6:52:00 PM ] Erasing FRP... error [ 3/1/2016 6:52:00 PM ] |
03-02-2016, 06:26 | #2 (permalink) | |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Quote:
Try to flash with good firmware and repeat reset frp steps. Regards Rehan Shaikh | |
03-07-2016, 18:09 | #4 (permalink) |
Insane Poster Join Date: Feb 2016 Location: panama city
Member: 2536862 Status: Offline Thanks Meter: 4 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Reset FRP/React/EE Selected model: SM-J120M Software version: 24.6 Searching Samsung USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.24.6 |
03-17-2016, 17:31 | #5 (permalink) |
Member: 2536862 Status: Offline Thanks Meter: 4 | Operation: Reset FRP/React/EE Selected model: SM-J120M Versión de Software : 24.7 Searching Samsung USB Flash Interface... detectado COM32 Configurar conexión ... Listo Leyendo PIT desde el teléfono ... Listo Searching FRP lock... Listo Erasing FRP... error Done with Samsung Tool PRO v.24.7 |
05-27-2016, 20:15 | #6 (permalink) |
Member: 2536862 Status: Offline Thanks Meter: 4 | Operation: Reset FRP/React/EE Selected model: SM-J120M Software version: 25.5 Searching Samsung USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.25.5 |
05-27-2016, 20:21 | #8 (permalink) | |
Freak Poster Join Date: Jan 2014 Location: Panama
Member: 2117710 Status: Offline Thanks Meter: 70 | Quote:
07-04-2016, 02:48 | #9 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAÑA
Member: 808967 Status: Offline Thanks Meter: 155 | Operation: Reset FRP/React/EE Selected model: SM-J120M Software version: 25.8 Searching Samsung USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.25.8 |
