02-18-2016, 23:55 | #31 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Nadi
Member: 210669 Status: Offline Thanks Meter: 97 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) File analysis... OK Total file size: 0x7A741740 (1959 Mb) Searching USB Flash Interface... detected COM222 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending hidden.img... OK Sending modem.bin... OK Flashing done (time - 00:02:17) Done with Samsung Tool PRO v.24.3 Searching Samsung USB Flash Interface... detected COM222 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.3 THANK YOU VERY MUCH BUDDY |
The Following User Says Thank You to kava For This Useful Post: |
02-20-2016, 15:22 | #37 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | Why are you downgrading the entire rom? It is new bootloader that is blocking the reset flash. Just downgrade the sboot and it will work just fine. No need to flash entire rom and wait 5 minutes when you can do it in 5 seconds. |
