03-01-2016, 18:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | j200g/dd frp unlock not done |
03-02-2016, 08:50 | #2 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | here is log of j200g- UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 24.4 Searching Samsung USB Flash Interface... detected COM30 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.24.4 |
03-02-2016, 08:52 | #3 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | now third set sm-g900f for frp lock but no frp lock button given, plz z3x team i have 3 sets which i return j200g, a800i and now samsung g900f plz do more work in frp lock section z3x team. |
03-11-2016, 14:47 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | Quote:
Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 24.4 Searching Samsung USB Flash Interface... detected COM15 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.24.4 | |
07-16-2016, 12:45 | #5 (permalink) |
No Life Poster Join Date: Nov 2014 Location: BADARPUR ASSAM (I N D I A) Age: 34
Member: 2298142 Status: Offline Thanks Meter: 240 | Definition Applied Start Detect device. Device detected OK. Downloading.. Get phone data.. Frp Lock Reset Launched... Searching For Frp 1.. Loading Data Please wait.. Rc Block Update ok... Processing Data... >>Done.. |
