02-13-2017, 10:14 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Instant Mobile Age: 45
Member: 694652 Status: Offline Sonork: 100.1669706 Thanks Meter: 1,005 | j200g writ cert error imei blank, base band unknown imei blank, base band unknown BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-J200G Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-J200G Android version: 5.1.1 Product code: Phone version: PDA version: J200GDDU1AOI3 CSC version: J200GODD1AOI3 CSC country code: India CSC sales code: INS HW version: Phone SN: RZ8GC0NT2NN Chip name: EXYNOS3475 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.7 |
