03-15-2017, 17:24 | #1 (permalink) | |
Freak Poster Join Date: Nov 2015 Location: karachi
Member: 2486328 Status: Offline Sonork: 100.1660495 Thanks Meter: 79 | J320A read code success but wrong code ? s Quote:
03-15-2017, 22:44 | #6 (permalink) |
Freak Poster Join Date: Apr 2012
Member: 1745512 Status: Offline Thanks Meter: 133 | To me also happens to me with the same compilation of software and the same model, here I leave the log of operation some solution would be appreciated UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J320A Software version: 27.8 Searching Samsung modem... detected COM66 Reading phone info... Ok Model: SM-J320A AP version: J320AUCU2APJ2 CSC version: J320AATT2APJ2 CP version: J320AUCU2APJ2 Product code: SM2J320AZABATT Phone SN: R28HB3LL92N Unique number: CQ30040A0D64CB3 Reading IMEI... Ok IMEI: 357417072xxxxxx (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: B7 1A 08 46 37 82 97 F6 51 CA 27 DF 6F F6 38 DB Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:01) Freeze code: 84280684 NET lock: 13558671 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.8 |
The Following User Says Thank You to retaco82 For This Useful Post: |
03-16-2017, 03:08 | #8 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | I always used z3x and done many j320a , j120a etc read codes All was successfully accept the codes from z3x You have to try first freeze code then net lock code Sent from my iPhone using Tapatalk |
The Following User Says Thank You to shahsoft For This Useful Post: |
