06-08-2017, 18:29 | #1 (permalink) |
Insane Poster Join Date: May 2016
Member: 2575895 Status: Offline Thanks Meter: 10 | J327P stuck in cdma mode without apn with this way the APN doesn't show and the gsm network is not able to be selected I have since then down couple more phones with the new root method and those show the apns and gsm mode perfectly but this original phone that was done with the only whenever I try the new root method its still doesn't give me the apn or gsm mode option any solution to this problem thanks |
06-08-2017, 18:37 | #2 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Cayman Islands
Member: 2529251 Status: Offline Thanks Meter: 275 | I have done hundreds of these unlocks with the old method which I've did post I have never had a problem with apn. Pm me for help Sent from my SAMSUNG-SM-G930A using Tapatalk |
06-10-2017, 05:46 | #4 (permalink) |
Member: 2529251 Status: Offline Thanks Meter: 275 | Apn apk . For all of you who are stuck and cannot access the APN ...... here is an app to help you please say thanks *https://mega.nz/#!7w4FwQTD!7UpM9txqE...cvP7zNANWE1av0 Sent from my SAMSUNG-SM-G930A using Tapatalk |
The Following 4 Users Say Thank You to cyc0d3d For This Useful Post: |
06-13-2017, 14:36 | #6 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | 1. Flash and hard reset 2. Debugging usb and OEM Unlock 3. Configure the connection to the terminal network Enter the cell to the "Settings" menu Enter the "Mobile Networks" option and then to "Network Mode" and select LTE / GSM / UMTS Then enter "Access Point Names" (from the English "Access Point Name" or APN). Here it is necessary to configure the access point according to the company with which the mobile will be used. |
