02-28-2017, 17:56 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Cayman Islands
Member: 2529251 Status: Offline Thanks Meter: 275 | SM-J327p unlock with files 100% Please flash the combination Use z3x to unlock using model J320P Then flash back stock firmware . See links below. If you have any problem PM me. Thanks to my team @darmiles :-) CSC https://files.fm/u/sb887fep AP https://files.fm/u/vzjdm7dc BL https://mega.nz/#!C5B1xaya!m-15LNYzq...tsIkbH22cXlvgU CP https://mega.nz/#!HoZV3RiD!5pg_LxdF3...Gvndbg7TeFg8q4 COMBINATION https://mega.nz/#!C1YSBJ5D!DVVXsvXIy...iz_92mSA0im8jk |
The Following 56 Users Say Thank You to cyc0d3d For This Useful Post: |
03-01-2017, 22:59 | #2 (permalink) |
Member: 2529251 Status: Offline Thanks Meter: 275 | Guys please post sucess after unlock. I only test with z3x input is appreciated Sent from my SM-G930F using Tapatalk |
The Following User Says Thank You to cyc0d3d For This Useful Post: |
03-04-2017, 20:22 | #4 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2112980 Status: Offline Thanks Meter: 2 | your method work perfect... Thank you very much for your help... Last edited by dejama979; 03-04-2017 at 20:28. |
The Following User Says Thank You to dejama979 For This Useful Post: |
03-13-2017, 02:36 | #9 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Tonga
Member: 2422331 Status: Offline Thanks Meter: 41 | After flash and do unlock its require root Operation: Unlock Selected model: SM-J327P Software version: 27.8 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU1APL1 PDA version: J327PVPU1APL1 CSC version: J327PSPT1APL1 CSC country code: USA CSC sales code: BST HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 RF cal date: 2016.12.15 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... false Super user right required true Done with Samsung Tool PRO v.27.8 |
The Following User Says Thank You to ChElEuLaVi For This Useful Post: |
03-13-2017, 02:40 | #10 (permalink) |
Member: 2529251 Status: Offline Thanks Meter: 275 | The new 27.8 update now supported model j327p on z3x but if you read it is still in test mode. Samsung Tool PRO 27.8 Update. Added: - support SM-J327P (Flashing, Read/Write QCN, Read/Write EFS, Read/Write SEC, Write CERT, Unlock(TEST)) Please use my method mentioned above it will not ask for root if you flash the combination file and unlock with model j320p. I have not tested the new software but will do so next week Wednesday as i have 120 pieces to unlock. I will try to unlock using j327p with combination. Until then use the method above Sent from my SM-G930F using Tapatalk Last edited by cyc0d3d; 03-13-2017 at 02:46. |
The Following 3 Users Say Thank You to cyc0d3d For This Useful Post: |
03-13-2017, 03:23 | #11 (permalink) | |
Member: 2422331 Status: Offline Thanks Meter: 41 | Quote:
thanks I try previous version Its works | |
03-13-2017, 03:24 | #12 (permalink) | |
