12-28-2017, 10:47 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | j327p unlocking problem UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J327P Software version: 30.2 Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU3AQJ3 PDA version: J327PVPU3AQJ3 CSC version: J327PSPT3AQJ3 CSC country code: USA CSC sales code: XAS HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 Security patch: 2017-08-01 RF cal date: 2017.01.13 IMEI: 356964080987941 Writing AT RIL... OK Initialization AT RIL... OK Unlocking... error Done with Samsung Tool PRO v.30.2 UNLOCK INSTRUCTIONS: Domestic Unlock: 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options', tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock Domestic' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-J327P Software version: 30.2 Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU2AQI2 PDA version: J327PVPU2AQI2 CSC version: J327PSPT2AQI2 CSC country code: USA CSC sales code: BST HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 Security patch: 2017-08-01 RF cal date: 2017.04.14 IMEI: 356964087664220 Writing AT RIL... OK Initialization AT RIL... OK Unlocking... error Done with Samsung Tool PRO v.30.2 while unlocking done with firmware aqf4 |
12-28-2017, 11:01 | #2 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 865454 Status: Offline Thanks Meter: 25 | SAME HERE...hope for SOLUTIONS... Waiting ADB device... OK Reading phone info... Model: SM-J327P Android version: 6.0.1 Product code: Not Active Phone version: J327PVPU3AQJ3 PDA version: J327PVPU3AQJ3 CSC version: J327PSPT3AQJ3 CSC country code: USA CSC sales code: XAS HW version: J327P.03 Phone SN: 00000000000 Modem board: MSM8917 Security patch: 2017-08-01 RF cal date: 2017.08.17 IMEI: Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Unlocking... error |
12-28-2017, 16:05 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | No solution for Qj3 also others tool say successfully but still locked |
The Following User Says Thank You to Mr_F10ch3 For This Useful Post: |
