02-26-2018, 10:10 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | J327U 7.0 B3 not B2 or B1 - Last firmware done. A lot of members says is impossible, but its not true Today i have done J327UUEU3ARB1 So we are not talking about U2 or U1 those are easy to manage. Android Security patch level February 1, 2018 ADB Must be Enabled, How ? Use brain Log from Z3X Code: [ 2/25/2018 7:18:00 PM ] Operation: Reset FRP [ 2/25/2018 7:18:00 PM ] Selected model: SM-J320Y [ 2/25/2018 7:18:00 PM ] Selected port: COM6 Z3X BOX Serial Port [ 2/25/2018 7:18:00 PM ] Software version: 30.8 [ 2/25/2018 7:18:00 PM ] [ 2/25/2018 7:18:00 PM ] Waiting ADB device... OK [ 2/25/2018 7:18:00 PM ] Reading phone info... [ 2/25/2018 7:18:00 PM ] Model: SM-J327U [ 2/25/2018 7:18:00 PM ] Android version: 7.0 [ 2/25/2018 7:18:00 PM ] Product code: SM2J327UZKAXAA [ 2/25/2018 7:18:00 PM ] Phone version: J327UUEU3ARB1 [ 2/25/2018 7:18:00 PM ] PDA version: J327UUEU3ARB1 [ 2/25/2018 7:18:00 PM ] CSC version: J327UOYM3ARB1 [ 2/25/2018 7:18:00 PM ] CSC country code: USA [ 2/25/2018 7:18:00 PM ] CSC sales code: XAA [ 2/25/2018 7:18:00 PM ] HW version: REV0.1 [ 2/25/2018 7:18:00 PM ] Phone SN: R28J63BDFEA [ 2/25/2018 7:18:00 PM ] Chip name: EXYNOS7570 [ 2/25/2018 7:18:00 PM ] Modem board: SHANNON305 [ 2/25/2018 7:18:00 PM ] Security patch: 2018-02-01 [ 2/25/2018 7:18:00 PM ] RF cal date: 20170628 [ 2/25/2018 7:18:00 PM ] IMEI: 35766************* [ 2/25/2018 7:18:00 PM ] Bypass FRP... OK [ 2/25/2018 7:18:00 PM ] For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' About Log : BLANG can prove it from their server Sharing is prohibited due non gracefully members We share share share and there is no thanks buttons pressed Some Supporter or Product manager says HI and he got 100 thanks button. All the best |
The Following 7 Users Say Thank You to Formingus For This Useful Post: |
04-26-2018, 15:14 | #2 (permalink) |
Freak Poster Join Date: Nov 2016 Location: karachi
Member: 2650777 Status: Offline Sonork: 100.650600 Thanks Meter: 161 | j327U 7.0 FRP New Methed handred persent Working https://mega.nz/#!gqB3RLpT!fRNz105NO...OaLwUkCZGzgQfg |
07-13-2018, 13:14 | #4 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
Fake file + password protected + ask 100 rupees. Any way, maybe is better in this way due non thankful members . When they will start pay instead of thanks button will realize what is meaning of thank button | |
The Following 2 Users Say Thank You to Formingus For This Useful Post: |
07-13-2018, 14:07 | #5 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | I don't have one of these phones to work with but an eng file should do the trick. The combination file for Binary 3 is out and free anyways... Just did a simple search on google and found the whole combination file, the eng boot, the eng sboot and even the eng modem already extracted. |
07-13-2018, 22:02 | #8 (permalink) | |
It will be nice if you check post date before you replay It will be nice if you check post date before you replay BTW jcdes Go for G928V U3 or S3 with your eng sboot for FRP About you ector same thing, go to support there is U3 and do it. | |
07-13-2018, 23:40 | #9 (permalink) |
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | After the war you either have veterans or dead people my friend... I did a G928V 7.0 a while back by flashing G928VVRS3BQB1 then selected G928T then Reset FRP/React/EE... Different people around the world do things in different ways, the method used is of no importance as long as the job gets done. |
The Following User Says Thank You to jcdes For This Useful Post: |
07-14-2018, 10:54 | #10 (permalink) | |
About veterans: 60 years old Veterans pretend in year 2010 that was in war 1941 while they want born yet. Back to subject About G928V 7.0 U3 or S3 that you remove FRP is lie, i didnt take that example for nothing. *G928V has locked bootloader* *Codes like *#0808# and all rest ones are prohibited* *Flashing boot.img will hang phone with loop vibrate due OEM Locked* *Devloper options cant be enabled with 7x tap due FRP Restriction* *Unpack modify repack boot.img will lead to change hex offset in img *and due flash will lead on Secureboot fail or recovery boot fail* *modify fota.zip , boot.img, recovery.zip that has build.prop inside will not *do the job* So you as old member should not misslead other members with fake information's. About LOG from Z3X it can say FRP Removed after flashing with COMBO but FRP Will remain untouched. Post non edited video with G928V 7.0 U3 with OEM Locked how you remove FRP you have 100$ for coffee All the best commander | |
The Following User Says Thank You to Formingus For This Useful Post: |
07-14-2018, 12:09 | #11 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Where i Want
Member: 1699006 Status: Offline Thanks Meter: 179 | I Had same problem with that set and didnt manage to remove FRP Z3X says OK but FRP Remain Developer Mode was disabled Waiting for Solution, if any one has solution please provide it Thanks |
07-14-2018, 12:17 | #12 (permalink) |
Member: 1699006 Status: Offline Thanks Meter: 179 | While searching i found this thread http://forum.gsmhosting.com/vbb/f453...-done-2269461/ There is arguing and 1 fake report that FRP is unlocked |
12-19-2018, 00:42 | #13 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2326182 Status: Offline Thanks Meter: 2 | flash this combination (COMBINATION_OYM_FA70_J327UUEU3ARC1) using ODIN than Flash this one (J327UUEU3ARB1_OYM3ARB1 only-sboot-boot-recovery-system-cache) than enable OEM unlock and than factory reset DONE |
The Following 2 Users Say Thank You to dubago77 For This Useful Post: |
