11-18-2017, 17:29 | #1 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1808452 Status: Offline Thanks Meter: 21 | J330F Enable diag port I need to enable diag port to perform 'read codes via server' operation. I have reflashed phone with original Product code firmware but still not working. Any idea please... I do not want to root phone as it may trip knox Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM133 Reading phone info... OK Model: SM-J330F AP version: J330FXXU1AQI2 CSC version: J330FNEE1AQI1 CP version: J330FXXU1AQF7 Product code: NEE Phone SN: R58J86BWLRN Unique number: CQE000EA3A87C64 Searching Samsung diag port... not found Done with Samsung Tool PRO v.29.7 Last edited by busfield; 11-18-2017 at 17:34. |
11-18-2017, 17:42 | #2 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | *#0808# didn't work? Quote:
11-18-2017, 17:42 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | /Settings/Backup and Restore/ Factory reset If still not ok, then do Wipe from recovery as well BR |
The Following User Says Thank You to maremestera For This Useful Post: |
11-18-2017, 21:24 | #5 (permalink) |
No Life Poster Join Date: Sep 2012 Location: UK
Member: 1816005 Status: Offline Thanks Meter: 299 | first use latest version 29.8 enable adb and oem unlock if this doesn't work try to flash older firmware version |
The Following User Says Thank You to gsmro2012 For This Useful Post: |
11-19-2017, 09:39 | #8 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | Flashing different region or different product code version into phone may result in reading wrong codes or not at all. Can anybody help with lower version of the same region product code for my phone? I will appreciate. Thanks |
05-17-2018, 08:29 | #10 (permalink) |
Insane Poster Join Date: May 2008 Location: philippines Age: 34
Member: 764223 Status: Offline Sonork: allan_canceran Thanks Meter: 465 | up, i have same problem j330f i can not enable diag port because *#0808# not working. already tried this but same problem http://www.techeligible.com/2018/01/...mode-by-codes/ |
