Old 12-07-2017, 12:11   #1 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 809
J330f unlock fail
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect the phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever ('Diag' algo):
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Press 'Read Codes via server' button, select 'Diag', write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings)
Reading codes using sever ('Upload' algo):
Knox warranty does not matter.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, select 'Upload' write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-J330F
Software version: 30.1
Checking Login and Password... OK
Ballance: 30 crd.
You have 30 credit(s) left. This opreratin takes 5 credits.Continue? Yes
Waiting ADB device...
Please, allow USB debugging on phone... OK
Reading phone info...
Model: SM-J330F
Android version: 7.0
Product code: SM-J330FZDDXSG
Phone version: J330FXXU1AQFB
PDA version: J330FXWU1AQF9
CSC version: J330FOJV1AQF9
CSC country code: UAE
CSC sales code: XSG
HW version: MP 0.400
Phone SN: R58J82VJ35R
Chip name: EXYNOS7570
Modem board: SHANNON305
Security patch: 2017-06-01
RF cal date: 20170812
IMEI: 358870083824189
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM10 detected
Calculating... error (1)
Done with Samsung Tool PRO v.30.1
Old 12-14-2017, 13:41   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 175,751
Ballance: 30 crd.
Model: SM-J330F
CSC sales code: XSG
Start... OK
thanks for report. we working on this problem.
just solution will ready we will add to update.
Old 12-21-2017, 16:13   #3 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 170
Hello but I have done this phone unlock and now all is ok.
Waiting for server answer... OK
Freeze code: 40919637
NET lock: 05269319
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Page generated in 0.19879 seconds with 7 queries
