11-24-2015, 13:53 | #1 (permalink) |
Freak Poster Join Date: Aug 2014 Location: bangladesh
Member: 2243030 Status: Offline Sonork: 1640811 Thanks Meter: 28 | j361h unlock done without root 5.1.1 Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP' to deactivate Google account activation lock. 4. Press 'Reset Reactivation Lock' to deactivate Samsung reactivation lock. Operation: Read Codes Selected model: SM-G361H Software version: 23.4 Searching Samsung modem... detected COM27 Reading phone info... OK Model: SM-G361H Version: G361HXXU0AOG3/G361HOJV0AOG1/G361HXXU0AOF8/G361HXXU0AOG3 Product code: SM-G361HZSDKSA Phone S/N: R51G73RB32Y Imei: 354202070155779 Unique number: CQN00A7CE6A0D72 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:38) Freeze code: 51827386 NET lock: 80950951 For check lock status: *#7465625# Done with Samsung Tool PRO v.23.4 |
