10-31-2016, 09:20 | #1 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1677416 Status: Offline Sonork: 100.1626947 Thanks Meter: 55 | J5 prime sm-g570f frp solution help plzz .... Any baddy have combination file..?? Operation: Reset FRP Selected model: SM-G570F Software version: 27.0 Waiting ADB device... timeout Phone not found First activate ADB Done with Samsung Tool PRO v.27.0 How to activate ADB Mode..??? Last edited by gsmnaushad; 10-31-2016 at 09:26. |
10-31-2016, 13:22 | #3 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up 14.click on massege then write Google in sms |
The Following 4 Users Say Thank You to Asad ali khan For This Useful Post: |
11-09-2016, 11:45 | #4 (permalink) |
Junior Member Join Date: Oct 2016 Location: ludhiana
Member: 2641193 Status: Offline Sonork: 100.1675747 Thanks Meter: 4 | Device: SM-G570M Operation: Apply FRP Patch Port: COM26 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-G570F Software: G570FXXU1APIA/G570FODD1API7/G570FXXU1API6/G570FXXU1APIA Init Download Mode... OK Port: COM27 : SAMSUNG Mobile USB Modem #4 Reading Data from Phone... Done Chipset: LSI7570 [HiSpeed] Applying Patch Data... . Rejected! Failed to apply FRP Pack! Please contact support. Elapsed Time: 00:51 [Ultimate Samsung Flasher v0.7] |
The Following User Says Thank You to chiragj48 For This Useful Post: |
11-29-2016, 15:31 | #5 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Sm-g570f not done frp Device: Samsung Device Operation: Reset FRP (New Method) Port: COM14 : SAMSUNG Mobile USB Modem #3 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7570 [HiSpeed] Resetting FRP Lock Data... . Done Closing Session... Binary Rejected! ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Once Phone is completely ON, wait a few minutes and then. goto Menu > Settings > Backup and Reset and do Factory data Reset. Elapsed Time: 00:16 [Ultimate Samsung Flasher v0.8] AFTER THIS ACTION PHONE GO THIS condition |
11-29-2016, 20:47 | #6 (permalink) | |
No Life Poster Join Date: May 2016 Location: IR
Member: 2575029 Status: Online Thanks Meter: 122 | Quote:
After reset frp flash with orginal file flash ur problem solved. | |
12-18-2016, 23:53 | #12 (permalink) |
No Life Poster Join Date: Nov 2014 Location: BADARPUR ASSAM (I N D I A) Age: 34
Member: 2298142 Status: Offline Thanks Meter: 240 | FIRST FLASH COMBINATION FILE Dev-Host - COMBINATION_G570FXXU1APJ2_HalabTech_HosamKashto.ta r.rar - The Ultimate Free File Hosting / File Sharing Service COMBINATION_OJV_FA60_G570FXXU1API2_OJV1API2_CL9218 515_QB10877448_REV00_ HERE IS FIRMWARE INS (INDIA) FILE INDIA Dev-Host - G570FXXU1API6_G570FODD1API7_INS_India_v6.0.1_Salma n.zip - The Ultimate Free File Hosting / File Sharing Service TRY AND POST RESULT...........................................T HANKS.......... |
The Following User Says Thank You to khalidahmed For This Useful Post: |
12-19-2016, 00:00 | #13 (permalink) |
Member: 2298142 Status: Offline Thanks Meter: 240 | AFTER FLASH Operation: Reset FRP Selected model: SM-G570F Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: SM-G570F Android version: 6.0.1 Product code: SM-G570FZDDINS Phone version: G570FXXU1API9 PDA version: FA60_G570FXXU1APJ2 CSC version: CSC country code: CSC sales code: HW version: MP 0.500 Phone SN: RZ8HA0KG5XV Chip name: EXYNOS7570 Modem board: SHANNON305 RF cal date: 20161008 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.5 |
12-19-2016, 13:11 | #14 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Jodhpur India
Member: 48238 Status: Offline Sonork: 100.54361 Thanks Meter: 397 | Quote:
WBR Jyoti | |
12-21-2016, 05:58 | #15 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1330911 Status: Offline Sonork: ED Thanks Meter: 11 | 10000% Solution: After work with realterm & entering to brouser, with file manager install this 2 files: 1. 1_Android_6_Google_Account_Manager.apk - 7.9 Mb 2. 2_com.rootjunky.frpbypass-1.0__1_.apk - 1.2 Mb Then enter "Your" Google account & restart your phone. Next next next... |
The Following 5 Users Say Thank You to elshod For This Useful Post: |
