03-20-2017, 10:51 | #19 (permalink) | |
Freak Poster Join Date: May 2014 Location: Al-Bakistan
Member: 2191194 Status: Offline Thanks Meter: 75 | G570F frp adb tested file Quote:
https://drive.google.com/file/d/0B_O...ZRSGs4ZVk/view | |
The Following 4 Users Say Thank You to ..Ali Abbas.. For This Useful Post: |
03-20-2017, 11:04 | #20 (permalink) |
Freak Poster Join Date: Mar 2015 Location: Bangladesh Age: 32
Member: 2364514 Status: Offline Thanks Meter: 390 | samsung G570F FRP Remove 1000%ok test solution dial your country emergency call https://www.youtube.com/watch?v=w2tHpXjFc0s |
04-02-2017, 06:21 | #21 (permalink) | |
Freak Poster Join Date: Jul 2006 Age: 45
Member: 316292 Status: Offline Thanks Meter: 102 | Quote:
1) simple connect wifi 2) wifi connected dont do next 3) click on more 4) add network 5) type anything in (Network Name) 6) press and hold on it (Cut Copy select all Asssist) 7) click on Assist google browser will pop on screen search MY Files attach OTG pendrive install android 6 google manager and install FRp reset browse and sign in reboot done android google 6 account : Download Android_6_Google_Account_Manager.apk free - Android Host FRP Bypass : Download com.rootjunky.frpbypass-1.0.apk free - Android Host | |
The Following 13 Users Say Thank You to SanjanMobile For This Useful Post: |
04-04-2017, 17:56 | #22 (permalink) |
No Life Poster Join Date: Jun 2016 Location: every ware in your hart
Member: 2590583 Status: Offline Thanks Meter: 198 | new security 2017/04/04 https://m.youtube.com/watch?v=kn6kahWxTuY Sent from my HUAWEI VNS-L31 using Tapatalk |
04-06-2017, 05:36 | #24 (permalink) |
Junior Member Join Date: Jun 2014 Location: Hoshiarpur Age: 31
Member: 2206704 Status: Offline Sonork: 100.1656616 Thanks Meter: 0 | J7 Restart Problem I Flashed My j7 With Odin But Prob Not Solve when power on its show blank screen and then restart. i flash4 files with difrent versions But Problem same, i replace new lcd Folder but same just show blank screen then restart and restart. Can Anyone Help me. It's urgent |
04-07-2017, 16:15 | #25 (permalink) |
Insane Poster Join Date: Dec 2008 Location: BERHAMPORE,INDIA Age: 36
Member: 935112 Status: Offline Sonork: 100.1675738 Thanks Meter: 15 | Zippyshare.com - G570F ADB OPEN FRP RESET FILE.tar frist write combination file....... after.... write ap..then write this file ....its 1000% work for me Last edited by mamunmandal; 04-07-2017 at 16:16. Reason: http://www74.zippyshare.com/v/ufeqkts2/file.html |
04-18-2017, 08:34 | #26 (permalink) |
Junior Member Join Date: Nov 2014 Location: Proddatur
Member: 2295125 Status: Offline Thanks Meter: 14 | J5 Prime G570F FRP Done 1000000% J5 Prime G570F FRP Done 1000000% just flash with COMBINATION_OJV_FA60_G570FXXU1AQA1_OJV1AQA1/file in z3x shell and u will get adb if not drag notification bar u will access settings app then go to developer option on and frp reset with z3x after that u have to flash stock rom must for proper work thanks z3x |
The Following 3 Users Say Thank You to shahussain5 For This Useful Post: |
04-24-2017, 14:17 | #27 (permalink) |
Junior Member Join Date: Feb 2014 Location: United Arab Emirates
Member: 2134743 Status: Offline Thanks Meter: 13 | g570f frp 6,0,1by umt G570F_COMBINATION_OJV_FA60_G570FXXU1AQA1_OJV1AQA1 flash with this file by odin then reset frp by umt dongle its work on latest version and use frp reset(adb mode)=======10000%tested by me |
04-25-2017, 18:59 | #28 (permalink) |
Junior Member Join Date: Mar 2007
Member: 473263 Status: Offline Thanks Meter: 15 | Quote: Originally Posted by betina View Post Sboot for frp samsung g570f only make hard reset to remove the code and give it with the z3x AND G570F frp adb file is here https://drive.google.com/file/d/0B_O...ZRSGs4ZVk/view thnx 100% useful |
The Following User Says Thank You to khanakbara For This Useful Post: |
04-25-2017, 19:11 | #29 (permalink) | |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | Quote:
Enviado desde mi KIW-L24 mediante Tapatalk | |
The Following User Says Thank You to GSM_FIX For This Useful Post: |
