12-09-2016, 06:35 | #2 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Pakistan
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | Bypass MSL... error (2) BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM16 SAMSUNG Mobile USB Serial Port Software version: 27.4.2 Checking CERT file... Ok KEY ID: 0338 Waiting ADB device... Ok Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: Not Active Phone version: J500FXWU1AOJ2 PDA version: J500FXWU1AOJ2 CSC version: J500FOXX1AOJ2 CSC country code: Czech Republic CSC sales code: ETL HW version: Phone SN: 00000000000 Modem board: MSM8916 RF cal date: NONE IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.27.4.2 |
12-09-2016, 12:14 | #4 (permalink) |
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | Reset MSL done not working.............. REPAIR INSTRUCTIONS: Activate Diagnostic Port: 1. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Select device in ADB settings. 2. Press 'Activate Diag' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Reset MSL Selected model: SM-J500F Selected port: COM16 SAMSUNG Mobile USB Serial Port Software version: 27.4.2 Reading phone info... Reading IMEI... Ok IMEI: 0 Reseting MSL security... Ok Reseting... Ok Reset MSL done.............................................. ................................ BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM16 SAMSUNG Mobile USB Serial Port Software version: 27.4.2 Checking CERT file... Ok KEY ID: 0338 Waiting ADB device... Ok Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: SM-J500FZWDXFA Phone version: J500FXWU1AOJ2 PDA version: J500FXWU1AOJ2 CSC version: J500FOXX1AOJ2 CSC country code: Czech Republic CSC sales code: ETL HW version: MP 0.400 Phone SN: 00000000000 Modem board: MSM8916 RF cal date: 2015.12.09 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.27.4.2 |
12-09-2016, 14:04 | #6 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: türkiye
Member: 1207296 Status: Offline Sonork: 100.1609587 Thanks Meter: 74 | please change old modem Quote:
12-10-2016, 08:32 | #9 (permalink) |
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | Z3x box not working sm j500f FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Write CERT Selected model: SM-J500F Selected port: COM16 SAMSUNG Mobile USB Serial Port Software version: 27.4.2 Checking CERT file... Ok KEY ID: 0338 Waiting ADB device... Ok Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: SM-J500FZWDXFA Phone version: J500FXXU1AOI1 PDA version: J500FXXU1AOI1 CSC version: J500FOJV1AOI1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone SN: 00000000000 Modem board: MSM8916 RF cal date: 2015.12.09 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.27.4.2 Z3X BOX NOT WORKING SM J500F............. ? |
12-10-2016, 08:41 | #10 (permalink) | |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Quote:
here is tested solution first flash this firmware https://drive.google.com/file/d/0B12...ew?usp=sharing after flash root with this file https://drive.google.com/file/d/0B12...ew?usp=sharing and post result 100000000% working all the best | |
12-10-2016, 08:53 | #11 (permalink) |
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | This site has already been tried.... [QUOTE=royalnasim;12212459]here is tested solution first flash this firmware https://drive.google.com/file/d/0B12...ew?usp=sharing after flash root with this file https://drive.google.com/file/d/0B12...ew?usp=sharing and post result 100000000% working THIS SITE HAS ALREADY BEEN TRIED BUT NOT SUCCESSFUL........................................ ............ |
12-10-2016, 09:26 | #12 (permalink) |
Member: 1037372 Status: Offline Thanks Meter: 557 | my log this file 1000% work here is my log Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: SM-J500FZDDINS Phone version: J500FXXU1AOI1 PDA version: J500FXXU1AOI1 CSC version: J500FOJV1AOI1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.400 Phone S/N: RZ8H417L37B Modem board: MSM8916 RF cal date: 2016.04.27 IMEI: Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0338 Writing CERT... OK Checking CERT status... OK Writing Slave CERT... OK Checking Slave CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.25.6 |
12-10-2016, 10:36 | #13 (permalink) | |
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | royalnasim Quote:
cert file plz............................................... .. | |
12-10-2016, 11:37 | #15 (permalink) | |
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | tnx bro help Quote: BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM28 USB Serial Port Software version: 27.4.2 Checking CERT file... Ok KEY ID: 0338 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: SM-J500FZWDXSG Phone version: J500FXWU1AOJ2 PDA version: J500FXWU1AOJ2 CSC version: J500FOXX1AOJ2 CSC country code: Czech Republic CSC sales code: ETL HW version: MP 0.400 Phone SN: 00000000000 Modem board: MSM8916 RF cal date: 2015.12.09 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.27.4.2 tnx bro help............................... this sat not working | |
