01-02-2017, 16:23 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: karachi
Member: 2486328 Status: Offline Sonork: 100.1660495 Thanks Meter: 79 | J500f cert write Done Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM100 SAMSUNG Mobile USB Serial Port Software version: 27.7 Checking CERT file... Ok KEY ID: 0338 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: Not Active Phone version: J500FXXU1AOFA PDA version: J500FXXU1AOFA CSC version: J500FOJV1AOFA CSC country code: UAE CSC sales code: XSG HW version: MP 0.600 Phone SN: R000000000R Modem board: MSM8916 RF cal date: 2015.08.11 IMEI: Writing AT RIL... Ok Initialization AT RIL... Ok Bypass MSL... Ok Checking for compatible phone and cert... Ok Phone KEY ID: 0338 Writing CERT... Ok Checking CERT status... Ok Writing Slave CERT... Ok Checking Slave CERT status... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.27.7 |
