01-14-2016, 13:26 | #2 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | Hello Bro try with latest veriosn you can found latest version in z3x shell try and post result Regards Rehan Shaikh |
The Following User Says Thank You to rehansk8879 For This Useful Post: |
01-14-2016, 21:23 | #7 (permalink) |
Insane Poster Join Date: Jul 2013 Location: Ecuador
Member: 1984260 Status: Offline Sonork: carlingasok Thanks Meter: 31 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM847 SAMSUNG Mobile USB Serial Port Software version: 24.1 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: Not Active Phone version: J500FXXU1AOK2 PDA version: J500FXXU1AOK2 CSC version: J500FOJV1AOK2 CSC country code: UAE CSC sales code: XSG HW version: Phone S/N: Modem board: MSM8916 RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.24.1 |
