12-02-2015, 07:20 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | j500f fail reset msl Waiting ADB device... OK Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: Not Active Phone version: J500FXXU1AOG1 PDA version: J500FXXU1AOG1 CSC version: J500FOJV1AOG5 CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: Phone S/N: RV8G71TMKGY Modem board: MSM8916 RF cal date: NONE IMEI: Checking Super user right... true Initialization RIL... OK Reseting MSL security... error Rebooting phone... OK Reset MSL done Done with Samsung Tool PRO v.23.5 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM347 SAMSUNG Mobile USB Serial Port Software version: 23.5 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: Not Active Phone version: J500FXXU1AOG1 PDA version: J500FXXU1AOG1 CSC version: J500FOJV1AOG5 CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: Phone S/N: RV8G71TMKGY Modem board: MSM8916 RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.23.5 |
12-23-2015, 12:08 | #10 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,282 | it still same BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Selected model: SM-J500F Selected port: COM347 SAMSUNG Mobile USB Serial Port Software version: 23.9 Reading phone info... Reading IMEI... OK IMEI: 0 Reseting MSL security... OK Reseting... OK Reset MSL done Done with Samsung Tool PRO v.23.9 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM347 SAMSUNG Mobile USB Serial Port Software version: 23.9 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: Not Active Phone version: J500FXXU1AOG1 PDA version: J500FXXU1AOG1 CSC version: J500FOJV1AOG5 CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: Phone S/N: Modem board: MSM8916 RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.23.9 |
The Following User Says Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
12-23-2015, 13:42 | #13 (permalink) |
Freak Poster Join Date: Mar 2007 Location: South Africa/Pakistan Age: 44
Member: 476940 Status: Offline Thanks Meter: 57 | [QUOTE=CHAUDHRAY ARSHAD;11496417]it still same BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Selected model: SM-J500F Selected port: COM347 SAMSUNG Mobile USB Serial Port Software version: 23.9 Reading phone info... Reading IMEI... OK IMEI: 0 Reseting MSL security... OK Reseting... OK Reset MSL done Done with Samsung Tool PRO v.23.9 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500F Selected port: COM347 SAMSUNG Mobile USB Serial Port Software version: 23.9 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: Not Active Phone version: J500FXXU1AOG1 PDA version: J500FXXU1AOG1 CSC version: J500FOJV1AOG5 CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: Phone S/N: Modem board: MSM8916 RF cal date: NONE IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.23.9[/QUOTE reset msl and restart the phone. then write cert. |
12-23-2015, 14:25 | #14 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,282 | still no luck Reading phone info... Reading IMEI... OK IMEI: 351821071205169 Reseting MSL security... OK Reseting... OK Reset MSL done Done with Samsung Tool PRO v.23.9 Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500F Android version: 5.1.1 Product code: SM-J500FZWAXFA Phone version: J500FXXU1AOG1 PDA version: J500FXXU1AOG1 CSC version: J500FOJV1AOG5 CSC country code: SOUTH AFRICA CSC sales code: XFA HW version: MP 0.400 Phone S/N: RV8G71TMKGY Modem board: MSM8916 RF cal date: 2015.08.04 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.23.9 |
12-23-2015, 16:44 | #15 (permalink) |
Junior Member Join Date: Jan 2007 Location: Colombia
Member: 430712 Status: Offline Thanks Meter: 4 | same problem samsung j500m Checking certificate file... OK KEY ID: 0338 Waiting ADB device... OK Reading phone info... Model: SM-J500M Android version: 5.1.1 Product code: Not Active Phone version: J500MUBU1AOH3 PDA version: J500MUBU1AOH3 CSC version: J500MUWA1AOH2 CSC country code: COLOMBIA CSC sales code: COM HW version: Phone S/N: RV8G91T11RJ Modem board: MSM8916 RF cal date: 2015.10.08 IMEI: Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.23.9 help with this problem |
The Following User Says Thank You to ecalambas For This Useful Post: |
