12-04-2015, 12:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | j500f frp fail phone nw bricked Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', enable 'USB debugging' in 'Settings'-'Developer options'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. Operation: Reset FRP/React/EE Selected model: SM-J500F Software version: 23.5 Searching Samsung USB Flash Interface... detected COM30 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.23.5 |
02-15-2016, 10:49 | #6 (permalink) | |
Freak Poster Join Date: Jun 2011
Member: 1595163 Status: Offline Thanks Meter: 51 | J500f Quote:
Z3x team.... do something.. all other xyz teams dongle working fine.. y bot z3. my is bricked now | |
