09-18-2017, 11:24 | #1 (permalink) |
Junior Member Join Date: May 2011
Member: 1571405 Status: Offline Thanks Meter: 1 | J500FN finaly i funod IMEI Repair Solution for z3x box user [Done] por z3x pro user imei null 1 step flash your mobile with combinstion file 2 root with your mobile 2 chek your mobile which i ripir my imei 01 j500fn model with z3x pro 29.2 i salect this model SM-G360H afer when you ripr imei reflash mobile with normal flash file thanks i hoppe new tips for imei repir but work with me any demg am not responsebal REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: SM-G360H Software version: 29.2 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-J500FN Android version: 5.1.1 Product code: Not Active Phone version: J500FNXXU1AOF9 PDA version: FA51_J500FNXXU1AOF8 CSC version: CSC country code: CSC sales code: HW version: Phone SN: RV8H31D93YH Modem board: MSM8916 RF cal date: NONE IMEI: Checking Super user right... true Checking MSL... OK Initialization AT RIL... OK Bypass MSL OK Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.2 |
The Following User Says Thank You to raj650 For This Useful Post: |
09-22-2017, 17:31 | #2 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Hungary Age: 48
Member: 47989 Status: Offline Thanks Meter: 40 | dear raj650, this not work because imei cert not patch. if not patch cert then no network because imei certi :fail |
The Following User Says Thank You to zaxgsm For This Useful Post: |
